Club Sponsors => Pete's Dub Stuff => Topic started by: PeteG40 on October 10, 2008, 11:45:14 AM
Title: Toothed pulley belts for sale - on behalf of club g40 £15.50 ea
Post by: PeteG40 on October 10, 2008, 11:45:14 AM
Right, we've sorted a supply for toothed belts.  They are german quality made under Continental by Contitech.
These are importantly the right length, width and tooth profile for PSD toothed belt pullies. So they shouldn't wear your pully out like wrong profile ones may. They are a HTD - high torque belt.
Always handy to have a spare in case of teeth strippage or belt snap.
These are £15.50 a belt and £3.50 delivery - paypal accepted.
Title: Re: Toothed pulley belts for sale
Post by: busy t on January 24, 2009, 10:37:57 AM
just recieved my belt this morning and it is too big...my pulleys say PSD on them so they are definately from pitstop developments, does the pulley size make a difference? will you be able to get one that is the same size as a polo 16v cambelt?
Post by: busy t on January 24, 2009, 01:07:29 PM
right scratch that previous comment^^
after some more research and a look at my charger i realised that you can move the charger to tension the toothed belt. there is a large allen key bolt that looks to me like the charger pivots on (to the right of the charger) and then another large bolt (to the left of the charger). are these the only two bolts i need to loosen in order to move the charger and tension the toothed belt?
Post by: PeteG40 on January 24, 2009, 02:54:27 PM
yes it is, although you sometimes have to alter the alternator position (a little bit of movement in this makes a lot of difference)
pete
Post by: busy t on May 06, 2009, 07:14:50 PM
can you do a 1020 for the same price?
Post by: PeteG40 on May 06, 2009, 07:23:04 PM
they only do 960s and 1040s  - apparently 1016 is another size and 1000 - but they tend to be custom made - our supplier doesnt do them.
Can you not get 1040s to fit, a few people (myself included and Samg40) have had to fiddle with the alternator/boost pipe. but they fit eventually!
Post by: busy t on May 06, 2009, 09:03:46 PM
I have the charger adjusted as much as it will go, and the mounting bracket for the alternator does not have a space to adjust the position. It's still too slack, it hits against the top engine mount. Any ideas?
Post by: PeteG40 on May 07, 2009, 08:13:27 AM
undo all alternator bolts. There are only mm of movement but shove it down and out as far as you can!.  then nip it up and try to tension the belt
Post by: busy t on May 07, 2009, 05:09:10 PM
Does the bracket on your alternator not allow any adjustment dknight? How have you got around it? You reckon a 1020 belt will do the trick?
Post by: quiksilver_jake on May 07, 2009, 05:24:36 PM
Pete do you do 1000? mine says 1000 8m omega HP optibelt
20mm width ?
Post by: PeteG40 on May 07, 2009, 05:48:47 PM
after andy strange told me - i adjusted my alternator, as did samg40 on here and it worked fine.
Can't get hold of 1000 or 1020s - they are custom lengths
1040s are easy to get hold of, hence why psd used them for their design
Post by: busy t on May 22, 2009, 12:58:50 AM
Have you managed to tension your belt (sounds wierd when said out loud :P) yet?
There is a part on the gsf web site which i reckon is the plate that attatches the bottom of the alternator to the block, with the gap to allow adjustment. Check out part no 90498. What do you think?
If not the only other option i can think of is a 1020 belt, however the cheapest i have been able to get them is £28 each from a guy on clubpolo.
This is the only problem with my car now and it is blagging my head.
Anyone any ideas?
Post by: PeteG40 on July 19, 2009, 08:54:17 PM
hmm, tbh I do think they are overkill - I've only ever heard of original belts snapping - or one where a 60mm pulley was used, which caused the top bearings to seize.
Post by: LeonL on November 07, 2009, 09:07:50 AM
Still sell these?
Post by: PeteG40 on November 07, 2009, 09:24:53 AM
we do yes
Post by: sean on November 07, 2009, 01:30:28 PM
I got a psd toothed belt kit but need a belt, wat one would I need?
Post by: PeteG40 on November 07, 2009, 02:11:42 PM
one of these 1040 8m belt should be right
Post by: PeteG40 on February 25, 2010, 11:21:30 AM
slight price increase - now £14 - due to increase in vat and increase in cost from suppliers
Post by: dazzle53 on February 25, 2010, 05:25:24 PM
can i get one of these belts?
thanks
darren
Post by: vwmk3jon on June 03, 2010, 04:10:43 PM
Any news on them belts Pete?
Got a spare which isnt perfect but will do if i need it!
Post by: PeteG40 on June 03, 2010, 06:25:09 PM
bloomin nora - only ordered them for you on monday!  i'll let you know as soon as they are with me!
Post by: vwmk3jon on June 03, 2010, 07:31:02 PM
Sorry. i have a habit of wanting bits at the last minute :lol:
Post by: vwmk3jon on June 08, 2010, 03:10:42 PM
Paypal'd the money across Pete :)
Post by: wbaxter90 on July 26, 2010, 07:12:33 PM
will a 1020 8m fit even though i need a 1000 8m? or does it have to be exact?
Post by: PeteG40 on July 26, 2010, 10:42:44 PM
couldn't tell you!
Post by: wbaxter90 on July 27, 2010, 10:57:42 AM
i can only really find the 1000s on german sites, but looks like thats my only way
Post by: PeteG40 on July 27, 2010, 11:16:31 AM
think i might've sorted a supplier.  Will get a couple in and you can test them - see quality etc, as they aren't sure what brand they can supply. Will be same price as other belts we supply £14+post.
Let me know if your interested.  May take a week to get to you
Post by: grungeisdead on December 03, 2010, 02:37:52 PM
still selling these mate?
after a 1040 x 20 belt. who manufactures these?
Post by: PeteG40 on December 05, 2010, 07:32:35 PM
we supply continental contitech ones - got some in stock
pete
Post by: jooshy63 on January 12, 2011, 03:03:46 PM
These still available?
Post by: PeteG40 on January 12, 2011, 06:38:59 PM
yeah - replied to your pm
Post by: 10pin on August 13, 2011, 12:53:58 PM
Was a supplier ever sorted for 1000 8m belts? cheers
Post by: Justin14100 on August 13, 2011, 01:31:22 PM
http://www.amazon.co.uk/Medway-1000-8M-20-Timing-Belt/dp/B002T8V2CG
Post by: PeteG40 on August 13, 2011, 05:32:30 PM
any body got any report on longevity of medway belts.... years ago psd used to say they weren't too cracking
Post by: beatboxG40 on February 15, 2012, 07:19:58 AM
Hey Pete, I took some advice and bort some psd phase one toothies with 65mm charger pully, can you supply me a belt to suit, pm me your payment details (paypal if still avaliable) and il get the money sent asap
thanks
andy
can you also chuck in a white rear club g40 sticker and put it on the bill, cheers
Post by: 1982mk1 on March 27, 2012, 06:00:29 PM
Hi, im after a belt to fit the 65mm PSD phase2 pulleys.
Which one would be best.
Cheers.
Post by: PeteG40 on March 27, 2012, 07:31:11 PM
the ones we sell should fit psd phase one and 2s - its the size belt psd designed pullies to be used with if you wnat one pm me
Title: Re: Toothed pulley belts for sale - on behalf of club g40 £14.50 ea
Post by: chase_g40 on August 26, 2012, 11:54:06 AM
Hi I pmd you yesterday about a belt I need and no reply are you still doing these ??
Post by: PeteG40 on August 26, 2012, 04:15:17 PM
can only supply 1040s for psd toothies - not 1000 for german steel toothed belt kits
Post by: quiksilver_jake on January 24, 2013, 12:37:34 PM
The 1000 8m ones mine uses an Optibelt Omega HP 1000 8m, (20mm wide) I did a couple of thousand miles no issues but hasnt been used in 3 years, I'm speaking with Optibelt currently through work on them just need to check the width on them but if they are 20mm the belts are £18 from them direct.
Mine toothies are the Austrian ones people were buying a few years back.
Post by: PeteG40 on January 24, 2013, 12:55:43 PM
i can ask about them from a belt supplier i use for the internal charger belts
Post by: quiksilver_jake on January 25, 2013, 12:26:23 PM
yeah could do Pete, I've ordered one to see if they are the same as what I have nearly £25 with postage! Yours are a bargain :)
Post by: rhyswills1 on April 13, 2013, 10:53:39 PM
Hi Pete can I order a belt for 65mm psd,s please what's ur PayPal address please
Post by: Ben.lopo on February 16, 2014, 03:05:32 PM
Hey pete can I get one please I got the psd 65mm pulleys off samg40 if that helps lol paypal later when I get home cheers
Post by: Agent47 on March 27, 2014, 08:07:15 PM
Hi Pete, did you ever get a review on those Medway 1000 8m belts? Can get 4 off amazon for the price of one from maxrpm, reckon I could go through 4 against 1 off those?
Post by: PeteG40 on March 27, 2014, 08:21:37 PM
no sorry - you could  try one?
Title: Re: Toothed pulley belts for sale - on behalf of club g40 £15.50 ea
Post by: rsmark86 on April 11, 2019, 06:01:09 PM
Pm sent regarding a couple of belts
