snapped a cv joint at the weekend so far i have stuck it on axle stands and have undid every bolt apart from the six bolts on the inner cv can anyone shed some light into what tool i need to get them off and how
thanks
M8 multispline. Not a torx, not a star headed what not, not an allen bolt or a socket. Some numpties try and sell you the wrong bits if you're not sure what you're after.
(http://i.ebayimg.com/00/$(KGrHqEOKi8E03iU,-u!BN(sl7EDV!~~_35.JPG)
If you've ruined them and aren't able to use the M8 tool then I'd suggest a multi sided (not sure the proper name) 12mm socket. The type with the internals like this; (http://www.teng.co.uk/images/products/large/600508RI_l.jpg)
You can tap it on the outside of the head, although it's only really a last resort as it ruins the bolt and i think they're a VW only part. used on everything across the VAG range though so scrappies should have loads. if you try and use a 6 sided socket you probably won't have much luck as it doesn't bite.
You may find it easier to use a couple of extensions to reach. Also, clean the head out with WD40 or scrape it out then tap the multispline in else you stand a good chance of rounding it off.
