Technical => Superchargers / G-Lader => Topic started by: JregGT on June 26, 2011, 08:53:48 PM
Title: Charger to intercooler Hose
Post by: JregGT on June 26, 2011, 08:53:48 PM
Evening folks, the spiral boost hose on my G40 is starting to look a little poopty now. In some of the ribs, obvious wear is showing. I don't think it is leaking now, but not sure it will hold up for too much longer.
So i'm just wondering what people have used as alternatives, I'm going to ring VW tomorrow, but I imagine one will be astonomical money. I'm sure I read somewhere that someone had got away with a 57mm 45 degree silicone hose, but similarily I remember seeing that one of those would be no good! And I can't find either of those posts again!!!
Cheers folks
Rich  :)
Title: Re: Charger to intercooler Hose
Post by: Jezza-7 on June 26, 2011, 08:58:27 PM
Quote from: JregGT on June 26, 2011, 08:53:48 PM
Cheers folks
Rich  :)
Yep thats ok to do. Its what i run and most people on here do as well as the ribbed ones are hard to come by.
Are you using toothed belts?
Post by: JregGT on June 26, 2011, 09:09:20 PM
Nice one matey, thanks for the quick reply, will get one ordered up. Yep I'm running toothed belts, that was another thing I was going to post about soon. When I fiited them the belt was suppiled with it, and I'm sure its 1000 in length, i've seen a few posts making me think I should be using a slightly sorter belt, some thing like 985? Would that be right, as i'm guessing my charger will be at the top of its adjustment really?
Rich
Post by: Jezza-7 on June 26, 2011, 09:27:09 PM
Ooo im not to sure about the belt length. I think that sounds about right, i thought it was 1080 but i might be thinking of something else.
Some people had problems when having toothed belts so the best thing to do is when you order the pipe, ring them and see if they can make the hose longer. That way it wont be too short and then you can cut to size. Viper performance hose's are good and they also do one with a special coating inside to help keep temperatures out. Takes a while to get though as they have to make it.
Post by: Jezza-7 on June 26, 2011, 09:30:00 PM
Are you using a psd kit? You should get one from pete on here as they are the right ones. Can get 960 and 1040.
Post by: JregGT on June 26, 2011, 09:55:41 PM
Cheers Jezza, will look into it, just had a quick scan on ebay for hoses and there seem to be a few on there, will have a look into lengths for those.
No the pullies aren't PSD ones, they are a set supplied by PhilJ. If those are the belt lengths generally gone by I would hope mine is o.k at 1000. I had no issues when fitting i.e tensioning it etc, just for some reason that length was sticking in my head.
Cheers again for the replies.
Post by: PeteG40 on June 27, 2011, 08:25:38 AM
german ones are 1000
psd ones are 1040 length
Post by: JregGT on June 27, 2011, 05:14:58 PM
Sounds right then, Cheers Pete
Rich
Post by: scotsjohn on June 27, 2011, 08:43:59 PM
1040 belts mean the oem hose is too short so you need a longer elbow. What toothed belt kit are you using though? If it's a German one I think they have a differant tooth profile; squarer than the PSD kit belts. Best check.
Post by: JregGT on June 27, 2011, 10:17:06 PM
It is a German one matey, I have ordered a 45degree bend with 6inch legs, so should be able to make it fit o.k even with the longer German belt.
Cheers folks
Rich
