Alright guys, fitted one of these off a mk2 golf 16v, bled all the brakes perfect no air whatsoever, but theyre binding theyre constantly on, any ideas?
Cheers.
Sounds like there's a blockage stopping the fluid bleeding back. Quite possible if it's a used master cylinder.
Its a brand new item dude :S.
sounds more like a dodgy rear cylinder to me
Ive fitted a brand new unit the one side only a few days ago as the bleed nipple snapped off in the old one so could that have anything to do with it?
maybe the other side - if its crusty in the drum, it'll stick open
Ah i see, how would that cause the fronts to stay on though?
if all four brakes are constantly on all the time then I'd probably say it's a duff master cylinder although I've never seen anything like that happen. Usually a duff master cylinder means you have no brakes.
