i got a py engine last year
why is the water rail at rear of engine diffrent to original engine.
original is push fit into rear of water pump and fixes to block
engine i purchesed water pipe is fixed direct to rear of water pump with m6 nuts and pipes are diffrent to header tank and 1 heater radiator pipe.
Most py blocks have the nuts, like a mk2 engine. Presumably they are both py code
4 py engines
2 genesis g40 are push kit type ??
2 g40 are nut type ??
i have a late 94 G40 and it uses a push type water pipe. weirdly enough my 1W engine has a bolt on pipe and i thought they didnt exist with a bolt type.
depends who was on shift when the casting was being done lol
