ABD Rotating Items (Pistons/Crankshaft/Rods) All balanced and pistons machined to reduce compression ratio. - This setup ran 206 bhp and over 200 lb ft of torque at Aldon on Tommo32s motor. Ideal to build a 1.4 G40 - £150
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0072.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0076.jpg)
3xG40 pistons & rods (one melted) - £100 or splits
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0098.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0097.jpg)
RPM Stage 2 Power Kit (Chip + 68mm Alloy Twin V-Belt Pulley) £80
(PPP Chip + PSD 65mm Steel Twin V-Belt Pulley) £100
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0106.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0105.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0101.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0107.jpg)
Lucas 54 Calipers stripped for powdercoating + seals + pistons and bolts (no carriers) - £40
GT Injectors x 4 - £20
BMW 330d intercooler - £80
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0113.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0114.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0115.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0116.jpg)
Merc Sprinter intercooler - £80
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0112.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0111.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0109.jpg)
brand new clutch & pressure plate mk1-3 - £30
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0087.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0082.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0085.jpg)
63mm iirc oil pressure gauge nos - £15
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0090.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0091.jpg)
VW Polo and Lupo OEM watercooled oil coolers. - £20 without or £30 with piping - retrofittable to other VW's
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0089.jpg)
Mocal Oil Cooler (Thermostatic type with thermostat removed and adaptor for oil pressure/temp sender + oil lines for fitting to remote cooler - £40
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0080.jpg)
(http://i16.photobucket.com/albums/b12/yousafn/DSC_0078.jpg)
All parts to convert an 8v for forced induction (either turbo or supercharged) for £350.
Includes
G40 ECU
G40 Engine Loom
G40 Throttle Body
G40 Inlet Manifold
G40 Injectors
G40 Exhaust Manifold
All boost pipes
G40 Intercooler
G40 Alternator
G40 Alternator & Charger Engine Mount
G40 Supercharger - Standard & Unserviced - £SOLD
5-Speed AHZ Gearbox (From a 1.3 SPI Loon) - Good working condition - £SOLD
Sent you a PM
Saf, not on the list but you got a mk3 alternator pulley laying around???
updated with the last few bits random bits left. interested in other G bits in swap, pref turbo related whyg?
hiya im interested in that clutch and spring plate dude where abouts are you if not how much for postage ?? cheers zeemanG40 .
Oil cooler sold.
In central manc mate postage will be bout 8 quid via courier.
Ta :)
Also got an ATV Gearbox, removed from my Mk3 G40.
Comes with 4 litres of VW Gearbox oil, Selector Rod Bush & Seal.
After £300 pounds for all the above, or £350 with the above items fitted (seal, bush and oil, not the box in your car)
can fit the gearbox into your car if required.
offers? all surplus to requirements and i could do with some room!
hi pal were bouts u from intrested in clutch
central manc mate, but i travel about a bit
