Technical => Engine and Transmission => Topic started by: T.hunter on January 13, 2011, 12:54:01 PM
Title: Oil flow diagram
Post by: T.hunter on January 13, 2011, 12:54:01 PM
Hi has any one got a Oil flow diagram for the g40
Also were is the oil pressure release valve and were would be the best place to put a mechanical oil pressure gauge on the block?
Thanks Tom.
Title: Re: Oil flow diagram
Post by: hayesey on January 13, 2011, 01:02:17 PM
the oil pressure relief valve is part of the oil pump in the sump.  Best place for a pressure gauge take off is by using a t-piece with one of the oil pressure sensors in the head.  The thread size is m10x1mm.
Post by: T.hunter on January 13, 2011, 01:10:41 PM
Ar brilliant thanks.
Post by: T.hunter on January 13, 2011, 01:17:51 PM
Is the oil pump and release valve all one unit or can it be taken apart? Ie: could in fit a new release valve if mine were to be bugerd.
Post by: hayesey on January 13, 2011, 01:39:13 PM
it's an integral part of half of the oil pump casing, you could in theory replace just that half of the casing (in fact I did this but I just happened to have a spare old oil pump knocking about).  I have a photo of it somewhere but I can't find it
