Just wondering what peoples power outputs are on here really, 0-60 times aswell would be nice with performance tweaks too.
Just to get an idea of what mine might be giving out as I'm not that sure.
Mods as follows...
Full PSD stainless steel exhaust system (decat)
SNS stage 5 chip
65mm Toothed belt Kit
Full blend charger (full service by Jabba at 143,070)
Jabba sport Induction kit with heat shield
Boost return mod
Samco hoses
It's hard to say from your spec above, you've not listed any LED's, neons or aftermarked air scoops etc. so it's won't be much faster than stock. having said that the samco hoses will give you about 20bhp's. Some of the big boys on here have fitted electric superchargers, ecotec valves and fuel line magnets and are pushing 500 - 600 bhp
:D :D :D
anyway
Block replaced at 150k with a PSD one rebuilt at 100K included, new oil pump, new rings, all bottom end shells, seals, gaskets etc.
Schrick Camshaft with vernier pulley.
Ported/flowed head, new valve and guides, gaskets, seals at engine rebuild.
Thinner metal headgasket,
GT manifold port matched to head,
51mm throttle body,
G60 green injectors,
Jabba induction kit and heatshield,
Boost return mod,
PSD 4 branch exhaust manifold and full PSD 2 box exhaust system(Fully heat wrapped) with receipts for around £700,
Helix Organic Clutch,
RPM Tuning Cast Alloy Sump (no longer make these),
Mocal Thermostatic Sandwich Plate with 16 row left front mounted oil cooler,
Stage 4 full blend charger,
65mm PSD Alloy Toothed Belts,
G-lader serviced June 2010, oil seals and apex seals with fresh klubber grease and new gates belt.
Custom mapped at PSD about 3 years ago with all upgrade parts fitted.
Water injection kit plumbed in and built in to activate at high boost. Not wired in at the minute.
ATF:- 170.17 Bhp
ATW:- 149.19 Bhp
Torque:- 141.33 ft-lbs
That first reply is just complete rubbish, second not much better. Your car will be 148 ponies with those mods and not a penny more.
Quote from: Raw on December 22, 2010, 12:24:27 PM
Hahaa, had to laugh at this interesting comment there, sounds like you know your stuff lol :-\
