Hi guys was just wondering if any one could help me as I'm quite new my fans not coming on iv changed the thermostat and the thermo switch iv shorted the fan out that works does anyone have any other ideas? Cheers
When you say thermo switch do you mean the one in the radiator? Have you checked the wiring to the radiator sender with a multimeter?
as sam says get the multimeter out but i also had a problem with the bullet style fuse not making a good contact between the sprung contacts, worth checking.
Ye the one on bottom right of the radiator that just screws in, wer bouts is the sender? I'm not that knowledgable at the moment :-\
Ok will have look at those contacts on the fuse mate cheers
ok just understood wat you said sender as in where the thermostat is :P
