Yo im at the finishing stages of getting my car running and would like a few little bits for it
i would like the boost pipe that goes over the radiator as at the moment im running a massive front mount intetrcooler and would liketo swap back to standard to compare
also i would like some toothed pullyies 65mm ones as my car is runing 65mm at the moment but just standard twin V belt
im considering buy a set of pullys but thought i would see if anyone had any before i went ahead
cheeers!
are you after the full set of pulleys? crank alternator and charger?
I think i might have that boost pipe you require. Will have a look.
If not I've definatly got the boost pipe pm me if you want it thanks
Cheers Jezza!
DKight yeah im after a full set of pulleys
sorry if the add was a bit vague
Hi, I have a full set of toothies with a 65mm pulley, they are brand new and unfited comes with one new belt also, and I have the pipe you are after.
Cheers Lee.
Sorry mate, i thought i had a spare one but cant seem to find it.
There are 2 other lads that have them though.
No worries jezza
ive messaged philJ about some toothed pulleys now ill see how much he wants
ive still got that boost pipe if you want it mate its just cluttering up my spare room !
i should have a full set of standard pulleys, i will check when i get home
