i need my cam belt changing ASAP so has anyone got a guide to how to do this? ( where to lock off the cam, crank and so on )???
thanks peeps
ohhh am i better off with VAG parts ( water pump/belt ) or can i use GSF parts??
anyone got any part number for ordering?? i haven't got a clue what year the engine is sooo.... :/ need help
also what haynes manual will i need for my Polo G40 1.3 engine ( sorry to be a pain im new to the G40 :) )
If you go to vw for water pump its on an exchange basis and they give you one with plastic blades on. Most people tend to prefer metal blades as the plastic ones can snap off/melt.
But you do get a year warranty on vag parts. I would go for the cam belt from them as its only £12 or something.
Quote from: Jezza-7 on November 29, 2010, 05:50:27 PM
Nice one... I don't have an engine code or year of the engine to get the parts so any clue where it I's?? I think mine it a py :/
No lock off kits for the old polo as far as I'm aware mate. There's a timing mark on the cam pulley and one on the inside of the cam belt cover. Remove the cambelt cover,take out the plugs, rotate the belt till these marks line up, then gently wedge both pulleys with something like pieces of soft wood. You will find things a lot easier if you loosen the offside engine mounting and jack the engine up at that end. Drain the coolant system then you can remove the waterpump. I'd replace with OE parts; pump and belt from any 1.3 90-94 will do. About £45. Secret of success is to be as gentle as possible so as not to disturb the pulleys. No Haynes specifically for the G40. Have fun.
Quote from: scotsjohn on November 29, 2010, 05:56:45 PM
thanks for you advice mate.... so basically if i can line up the marks before hand they should stay in place if im soft handed
This is that you need
water pump 030 121 005LX £34.00
O-ring water pump 030 121 043B £3.00
timing belt (late) 030 109 119A £14.73
There is a £20 surcharge on pump?
Quote from: Jezza-7 on November 29, 2010, 06:23:43 PM
you legend :) thanks mate... so if i take my old water pump bk ill get £20 back??
Yeah. I think its £20 but best thing to do is take it in when you buy the new one. And if you get any problems then go straight back to them but keep the receipt or they wont do jack. Whats happened to me before but i mingled around it and they got me a new pump and fitted free of charge.
Quote from: Jezza-7 on November 29, 2010, 06:52:54 PM
TOP LAD thanks for the advice it all came in at £105 and will hopefully be ready to be picked up thursday :)
thanks for all your help... i might get a lot of pics and make a guide up
iv got one problem with lining up the timing marking.... basically my G has an eaton charger and dose not have the V belt setup ( think its a 20v pulley ) soo how will i sort that out.... am i best off lining up the top mark then making my own mark on the crank pulley??
Yeah, before taking the old belt off
Quote from: hayesey on December 05, 2010, 12:02:49 AM
im going to tackle the cambelt tomoz so thanks for your help lads, ill let you no how it gos....
one last think it is 1/4 of a turn for the tightness of the belt.
thanks dudes
90 degress on the longest part of belt i think.
Quote from: Jezza-7 on December 05, 2010, 09:41:07 PM
So about 1/4 of a turn? Or is it less/more
1/4 = 90 degress.
90 degrees with two fingers between the water pum
p and cam sproket is what they hanynes says that's what I've done mine to.
Quote from: dani1326 on December 06, 2010, 09:24:41 PM
are you really asking that question?!
Quote from: hayesey on December 07, 2010, 11:29:31 AM
yup just making sure... im not ust to timing belts iv only ever done timing chains on my mk2 VR6
Quote from: dub-disaster on December 07, 2010, 12:20:45 AM
im got the day off tomoz so ill be doing the belt.... how do you mean two fingers?? could anyone scan up the haynes page please :)
iv ordered my hayes last week but still hasn't turned up and the belt needs doing asap
thanks
I have got a pdf format if you want it emailed to you?
Quote from: Jezza-7 on December 13, 2010, 03:58:54 PM
That would be fantastic I'll pm you my email addy
