Technical => Engine and Transmission => Topic started by: dani1326 on November 05, 2010, 05:35:09 PM
Title: polo 6n G40 ( EATON )
Post by: dani1326 on November 05, 2010, 05:35:09 PM
Hay all iv got myself a polo g40 6n  but there is one thing I need to sort out....
When driving at a constant speed or setting off it splutters and jolts not very often but I'd like to sort this out ASAP any idears??? it only dose it once iv ran on boost but i if i dont run it on boost from starting it up is dosent do it so i no its not the ignition or timing.... Been told I need an Ecu chip is this correct??
It's running an EATON M45 and a front mout intercooler and I think that's all...
Also is there anywhere that stockes a toothed belt kit for the eaton charger/ G40 set up??
Title: Re: polo 6n G40 ( EATON )
Post by: Justin14100 on November 05, 2010, 06:16:14 PM
Quote from: dani1326 on November 05, 2010, 05:35:09 PM
Did sam tell you if it was a standard chip or a different one do you know?
First place I would look is engine sensors - look for lambda, blue temp ect
Post by: dani1326 on November 05, 2010, 07:38:53 PM
I'm sure he said all it needs is an Ecu chip to cure it so im assuming its a standard chip.... Not sure if I can but could I put it on VAGCOM as it's an older Ecu???
How do I check all the sensors??
Post by: Justin14100 on November 06, 2010, 09:07:13 AM
Quote from: dani1326 on November 05, 2010, 07:38:53 PM
http://www.polog40.co.uk/forum/index.php/topic,214.0.html
Give that a good read mate - Shame its running a standard chip; you know what boost its running? Just a re-map would really get you a shed of power if its more than the standard 0.6 /0.7 bar of boost!
Post by: dani1326 on November 06, 2010, 12:35:11 PM
Quote from: Justin14100 on November 06, 2010, 09:07:13 AM
It's running and holding 11psi until belt slip..... im just going to buy all new sensors.... what sensors will i need>?
Post by: Andy on November 06, 2010, 02:34:46 PM
What's the full engine spec (inc. injector size)?
What chip are you currently using?
What spark plugs are you using?
Post by: Justin14100 on November 06, 2010, 02:38:26 PM
Quote from: dani1326 on November 06, 2010, 12:35:11 PM
Blue temp - always VW
lambda
http://cgi.ebay.co.uk/NEW-BOSCH-LAMBDA-SENSOR-VW-Polo-Coupe-1-3-G40-PY-90-94-/180562355730?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a0a5ae612
try those for now - but i reckon its the map.
Any, from what I know its a totally standard engine, standard injectors, should have standard plugs <- dont know
and what i think from what danni is saying it has a standard map - hardly ideal for an eaton setup!
Post by: dani1326 on November 06, 2010, 04:04:13 PM
Quote from: Justin14100 on November 06, 2010, 02:38:26 PM
lambda
yeh standard apart from the eaton.... what would be the best injectors, plugs and camshaft ?? im going to get jabba to do a costtom map on her once iv got and fitted all the parts
Post by: Andy on November 07, 2010, 05:22:42 PM
PSD did some 'Eaton' spec camshafts - they were very lairy and had a lot of overlap. They pop up secondhand from time-to-time.
If you're running 11psi then I'd keep the standard injectors and standard camshaft for the time being, and use standard plugs - Bosch W5DP0 or NGK equivalents.
The boost delivery on an Eaton is very different to a G40, so running on a standard G40 map won't be helping things at all. I don't have any Eaton maps on file for standard injectors, and to be honest as most of the Eaton setups knocking around are different to one another I'd suggest a full remap as you're planning is the best bet. Jabba will be able to do you a dyno-remap I'm sure, but we (Polo-PP) also offer G40 remapping too.
Post by: dani1326 on November 07, 2010, 07:04:27 PM
Quote from: Andy on November 07, 2010, 05:22:42 PM
thanks for the advice.... iv got chance to get hold of a full PSD toothed belt kit and a PSD ecu chip would that chip be ok without the camshaft?
Post by: Andy on November 07, 2010, 07:18:18 PM
It depends what spec the chip is for...
There are some PSD Eaton chips out there for cars with a bigger MAP sensor (to run over 15psi of boost), some for 330cc injectors, some for 250cc injectors, some for the Eaton spec cam, some for standard cam etc. etc. So I'd ask the seller about the chip!
Also find out what pulley sizes the PSD kit comes with - they did some smaller pulley'd versions that'll kick out over 15psi of boost.
Post by: dani1326 on November 07, 2010, 09:26:23 PM
Quote from: Andy on November 07, 2010, 07:18:18 PM
good idear you told me to do that.... here is his reply......
::::There isn't a charger pulley, just the alternator and crank pulley, I do have the a charger pulley but it is for the g40 charger so would not fit the Eaton.
The low boost chip is for a psd camshaft, green injectors, 51mm throttle body not sure about the map sensor but I will dig the chips out tomorrow and let you know the full spec.::::
and that would of been a waist of over £300 i owe you one buddy
Post by: PeteG40 on November 08, 2010, 08:29:19 AM
from what i recall the eaton shaft has to be taken off and a key way machined into it... then a custom toothed pulley made for them.
they are probably unlikely to turn up second hand.  As i recall PSD only made 9 eaton kits.
Post by: hayesey on November 08, 2010, 09:45:28 AM
yes the standard pulley on an eaton is pressed on so some fettling is required to make a nice removable pulley fit.
Post by: lance on November 08, 2010, 06:11:56 PM
wonder if they made a toothed belt kit for the mini?
Post by: Justin14100 on November 08, 2010, 07:38:39 PM
dani can you not just tension them tight enough till there isnt any slip or get a new belt?
Post by: dani1326 on November 09, 2010, 04:19:10 PM
Quote from: Justin14100 on November 08, 2010, 07:38:39 PM
thats what im going to do.... im going to make my own costume best setup... also use a 15% smaller pulley off the mini  ;D
whats the best camshaft for the eaton setup??
