Technical => Chassis & Braking => Topic started by: dub-disaster on October 01, 2010, 06:29:01 AM
Title: 22mm master cylinder
Post by: dub-disaster on October 01, 2010, 06:29:01 AM
Doing my brake upgrade with 256mm set up and 22mm master cylinder, problem is I bought the master cylinder brand unused but from a bloke on club polo. But when looking at it next to my old one it looks identical evan down to the part numbers on the side are the same although they look to be different brands.
   Is there any thing obvious I can look for to confirm it's a 22mm one ??
Title: Re: 22mm master cylinder
Post by: PeteG40 on October 01, 2010, 09:07:39 AM
stock ones have 3 outlets and 22.2mm have 4 outlets (one blanked off)
Post by: dub-disaster on October 02, 2010, 03:27:04 PM
Cheers pete
Post by: dub-disaster on October 03, 2010, 08:17:50 AM
My old one had 4 outlets with one blanked of by a bolt does that mean it was probably a 22.2 mm job ? Do the standard ones only have 3 connections then and not just 4 connections with one blanked of ?
Post by: PeteG40 on October 04, 2010, 09:21:19 AM
Quote from: dub-disaster on October 03, 2010, 08:17:50 AM
sounds like you havea 22.2 fitted yeah.  Stock ones only have 3
Post by: JregGT on October 04, 2010, 04:52:20 PM
For this conversion, is it simply a remove the 19mm and replace with the 22.2mm? Other than the blanking plug, nothing else?
Cheers Rich
Post by: dub-disaster on October 04, 2010, 05:01:42 PM
Yup looks like I've got a spare 22.2mm one aswell ;)
Post by: JregGT on October 11, 2010, 07:51:11 PM
Meant to ask also, use the original polo brake resevoir?
Post by: cheys03 on October 11, 2010, 07:57:27 PM
Yup, original reservoir fits with a little 'gentle' push.
Post by: JregGT on October 11, 2010, 08:02:21 PM
Lovely job, thank you.  ;D
