i know this is quite a common topic, but really could do with a bit of advice on my charger rebuild!! is it best to just go for the r1 rebuild or is stage 4 just as good?? and is jabbasport the only place to have the rebuild done? only the last rebuild was done by pitstop devlopments and as they are no longer you can see how long ago it was last serviced!! currenty running a 68mm pully but would like to go to a 65mm pully!!
with thanks guy any advice would be good cheers james
have a word with PPP, they can organise rebuilds. If you do use jabba, then no, a stage 4 isnt the same as an R1, stage 4 only includes very light porting where as R1 takes off more material and flows slightly more.
