Club G40 => General Car Chat => Topic started by: demoG40 on July 17, 2010, 12:17:28 PM
Title: problem with oil pressure light/buzzer on my g40
Post by: demoG40 on July 17, 2010, 12:17:28 PM
hello.
I have a problem with my G40, I put a video so you can see light bulb as oil pressure, but the buzzer does not sound, and does it under 2000 rpm, and the car manual says that below 2000 rpm can not light or sound.
the oil level is correct.
when that happens, soon after you stop.
the buzzer function properly, which in turns fast if it sounds and lights.
forgive for my English, am Spanish and use the google translator.
a greeting.
and video
http://www.youtube.com/watch?v=8_tAzgW9HHE
thanks
Title: Re: problem with oil pressure light/buzzer on my g40
Post by: AlexG40 on July 17, 2010, 04:11:01 PM
Bienvenido de Inglaterra, que tendría la presión de aceite revisado por un mecánico para que usted pueda estar seguro de que hay un problema. Puede ser un sensor defectuoso o la luz. ¿Qué es la lectura en su odómetro?
Yo no conducir el coche demasiado hasta que esté seguro que usted no tiene un problema con la presión.
Perdona mi español, he usado traductor de Google!
Post by: demoG40 on July 18, 2010, 11:30:20 PM
How is the pressure? in bar or psi?
Post by: Bucker on August 09, 2010, 03:26:00 PM
Quote from: demoG40 on July 18, 2010, 11:30:20 PM
Hey!!
Que tal tio!!   ¿¿Conseguiste solucionar el problema??
