Technical => Engine and Transmission => Topic started by: Richg40 on July 01, 2010, 10:07:06 PM
Title: GSF main bearing set part no.
Post by: Richg40 on July 01, 2010, 10:07:06 PM
I need a set of main and big end bearing asap. Is this the GSF part number for the std main bearings for a G?>   161VG0210
Title: Re: GSF main bearing set part no.
Post by: Richg40 on July 04, 2010, 07:37:18 PM
anyone any ideas?
Post by: gti jack on July 04, 2010, 09:38:49 PM
cant you cross them with gsf and vw??
Post by: Richg40 on July 05, 2010, 10:00:20 PM
Ok, well this is the gsf description.....
161VG0210  MAIN BEARING SET-STD    PO All With Oil Hole    21.60
so.... is there any reason to buy 2 sets as it does state "All with oil hole"?
Post by: hayesey on July 05, 2010, 10:02:29 PM
I can't see any point in the oil hole in the top half of the bearing anyway, there's no oilway under where the hole is!
Post by: Richg40 on July 12, 2010, 10:48:33 AM
turns out they dont all have holes in, or grooves so i still need to buy 2 sets. You get 6 with grooves and 4 without. Still a bargain compared to genuine though.
Post by: Oily Fingers on July 20, 2010, 09:07:25 PM
whats the quality like of the GSF bearings??? i need these to start rebuild the crank etc
Post by: Richg40 on July 20, 2010, 10:18:55 PM
they look decent enough to look at.
Post by: woody02 on July 21, 2010, 06:36:57 AM
just put a set of gsf mains in my block, looked good quality (kobenschmidt). I had to buy two sets to get the oil hole in both halves. If you need all the gaskets for the rebuild phone rs engine supplies and speak to Nick 01233661458, he got me all the gaskets, rings big ends e.t.c
Post by: hayesey on July 21, 2010, 09:30:59 AM
can anyone take a photo on the non-hole ones that GSF supply?  Just interested to see what the differences actually are.  As I said before the hole in the half of the bearing that goes into the bearing cap seems useless to me as there's no oil way underneath it.  But if they also don't have grooves in then that seems bad.
Post by: woody02 on July 21, 2010, 01:33:18 PM
Quote from: hayesey on July 21, 2010, 09:30:59 AM
still got my halves that are no good, il post a pic when im home from work
Post by: Richg40 on July 21, 2010, 07:33:00 PM
Ok, so if you bought a second set you might have some spare ones with grooves in for sale?
Post by: hayesey on July 21, 2010, 07:44:42 PM
I assume he bought two sets and then used all the grooved ones from each.
Post by: woody02 on July 21, 2010, 08:40:50 PM
Quote from: hayesey on July 21, 2010, 07:44:42 PM
i did. only the plain ones left over.
Post by: Richg40 on July 21, 2010, 09:32:14 PM
maybe you bought a different set to me. Mine had 6 with grooves and 4 without.
Post by: Oily Fingers on September 08, 2010, 09:20:56 PM
has anyone used these on an "uprated" g40 engine??? this is the next step of my eaton build.
joel
