still having issues when i fit my boost gauge! same as before no boost what so ever! would really like for this to work!
Help!!
thanks in advance
Ross
Where did you placed the t-piece?
dont know what its called but it was to the right of the throttle body underneath the boost pipe!
can you take a photo of were you have connected the t-piece?
Quote from: hayesey on June 20, 2010, 12:39:10 PM
i will do yeah! but im gonna try n fit it again to see if it works! cos i found a boost leak and my acceleration has greatly improved since curing it!
having sorted that boost leak, the gauge is now working! took it for a drive, and at about 6000rpm in second it was at about 12/13 psi. rigged the light to the actual light switch as i have mounted it in the drivers side air vent! all good now!
thanks to all with input!
Ross
