Technical => Exterior and Interior => Topic started by: xrrich on June 08, 2010, 09:37:24 PM
Title: I Hate Sunroofs
Post by: xrrich on June 08, 2010, 09:37:24 PM
Right, you might have the same problem
I have the pop up style VW sunroof,
It leaks at the corners, Also lets in wind whilst i drive,
Ive tried to ajust it but its as tight as it goes and im getting wet, :(
Is it the seal?
The handle closes fine but doesn't compresses the rubber as much as it should.
Help would be great
Rich
Title: Re: I Hate Sunroofs
Post by: j.barnett on September 29, 2010, 08:57:56 PM
i would guess the frame is twisted and buckled as have had this on a few cars at work!! can fit new or remove and black tiger seal under the frame, tighten back down making sure you tighten all screw/ bolts at same rate to stop further buckling!! i alway put way too much tiger seal on it seeps out seals propley ( any excess you can wipe off and smooth with damp rags )      just a warning can be messy and a bitch on hand so wear gloves!!!
