Technical => Engine and Transmission => Topic started by: spookey on June 04, 2010, 04:09:26 PM
Title: G40 alternator mounting bolt same as other mk2/3 polos?
Post by: spookey on June 04, 2010, 04:09:26 PM
hi guys my alternator mounting bolt (the big one on the top) made a dissapering act on the way down to Plymouth last weekend and im now looking for a replacement would any 1-3 polo alternator bolt work or is it a g40 specific item?
Thanks Luke
Title: Re: G40 alternator mounting bolt same as other mk2/3 polos?
Post by: vwmk3jon on June 04, 2010, 06:54:44 PM
I was in my local VW asking this the other day. one was a m8 x 111 iirc and you need a m10 x 120. £1.88 each
Post by: spookey on June 04, 2010, 07:03:06 PM
sweet thanks for that Jon. is there any spacer/washer things or anything else needed to position the alternator? or is it just a bolt? i only say this because ive lost every thing from that bolt.
Cheers Luke
Post by: vwmk3jon on June 04, 2010, 07:34:01 PM
Including the spacer? if so theyre obsolete from VW so its either get one made or DIY it.
Post by: spookey on June 04, 2010, 09:31:57 PM
ow bugger hoping u wernt guna say that :( yea the hole lot dropped off all ive got is the alternator and the engine mount  ::)
Post by: vwmk3jon on June 04, 2010, 11:28:26 PM
I pikeyed mine until i could get a spacer made up. A suitable length of pipe will do it.
Post by: spookey on June 05, 2010, 01:44:26 PM
apparantly a 15mm socket and a rubber bung will do the trick so a certain build thread told me  ;)
hopfully i can get the size of the spacer and get one made up at a local engineering firm near me.
cheers for the help.
Post by: vwmk3jon on June 05, 2010, 11:37:35 PM
Quote from: spookey on June 05, 2010, 01:44:26 PM
You work with what you have. I have an angle grinder but im more dangerous than productive  :P
Post by: GAF2 on June 06, 2010, 05:46:15 PM
the same thing happened to me, for the spacer i went to my local cylinder head workshop and got a 8mm (iirc) valve guide, just said to the guy it needed to be at least X long (cant remember the length) he gave me one for nothing, i cut it to length, job done.
