Technical => Engine and Transmission => Topic started by: g40Ross on May 28, 2010, 04:16:01 PM
Title: boost gauge
Post by: g40Ross on May 28, 2010, 04:16:01 PM
dont know if this is the right section but could someone post me a picture of which line the tubing goes into! car is pretty much standard!
Ross
Title: Re: boost gauge
Post by: hayesey on May 28, 2010, 05:24:06 PM
don't have a picture but it's normally the one between the fuel pressure regulator (flying saucer thing on the end of the fuel rail) and the one way valve on the brake servo hose.
Post by: g40Ross on May 28, 2010, 06:19:30 PM
boost gauge is fitted! minus the light being wired up (need some more cable)
cheers heyesey
Ross
Post by: g40Ross on May 28, 2010, 08:26:42 PM
having fitted my boost gauge it has killed the forced air from the charger! so its just like driving a gt at the moment!
this is the gauge i have -
(http://i732.photobucket.com/albums/ww325/rossedC/Car/150w_SWG527.jpg)
i fitted it here -
(http://i732.photobucket.com/albums/ww325/rossedC/Car/280520101143.jpg)
(http://i732.photobucket.com/albums/ww325/rossedC/Car/280520101144.jpg)
is this in the right place or should i of put it the other end of the line i connected it too?
please help as it has really pissed me off!!
Ross
Post by: g40Ross on May 28, 2010, 08:50:36 PM
i have now just removed the boost gauge from the car and the charger is still dead please help???
Post by: cheys03 on May 28, 2010, 09:07:00 PM
Looks like you have a boost leak maybe?
(http://i734.photobucket.com/albums/ww343/cheys03/untitled-1.jpg)
Post by: g40Ross on May 28, 2010, 09:24:04 PM
could it have any thing to do with the amount of oil thats in the car? as i just took it for a spin and the oil light flashed and beeped! i checked my oil and i said it was pretty much dry?
Ross
Post by: vwmk3jon on May 28, 2010, 11:49:39 PM
I would seriously check your oil and top up if necessary. Dodgy oil pump?
Post by: g40Ross on May 29, 2010, 12:09:19 AM
well i have topped up my oil! before i did this though the tappits were really loud and now i have topped it up its stopped!
its not the oil pump, i have an oil leak from the rocker cover gasket which i have just replaced. today i put some gasket sealent on left it for 4 hours as it said to do and it still leaks! kept her running on the drive and looked at the seal and i can see were its coming from, its behind the cam pulley right in the corner of the arch of the cam cap. could my head need skimming?? im thinking i may even buy a new rocker cover n try that!
Ross
Post by: g40Ross on May 30, 2010, 04:34:31 PM
bump
Post by: PeteG40 on May 30, 2010, 08:10:33 PM
Quote from: g40Ross on May 29, 2010, 12:09:19 AM
Ross
it could be the cam oil seal
Post by: g40Ross on May 30, 2010, 09:27:19 PM
[/quote]it could be the cam oil seal[/quote]
ill have a look at that!!
Post by: AlexG40 on May 30, 2010, 11:58:40 PM
Did you torque tighten the cam cover when you fitted the new gasket or just horse it up as hard as you could?
Post by: g40Ross on May 31, 2010, 06:27:52 PM
dint torque tighten no! was i supposed to?
