Im looking to replace my old braided hose to go with the fresh rebuilt charger/engine etc. Wheres the best place to get them from, are vw ones braided or just rubber hose?
the feed hose is braided from vw yes
Your local hydraulic supplier would most likely be willing to make you one using the old one as a pattern. I can't say if this would be cheaper than VW, though.
anyone got the part number for this as mine could probably do with replacing aswell!
I'd be interested to know too as mine needs replacing and the oil drain one too probably.
Braided Hose :052 145 443
The return is made up of a solid piece of pipe with a hose and banjo union on the end, Do you want part numbers for that?
is it wise to use the hoze with stainess banjo bolds my hydraulic supplier made up for me os is it a certon sze to aid flow etc ?
As long as it's the same bore size and length as an original hose there's no problem.
