Technical => Chassis & Braking => Topic started by: grayg40 on April 21, 2010, 10:12:06 AM
Title: bottom arms?
Post by: grayg40 on April 21, 2010, 10:12:06 AM
as above, are the bottom arms on the G the same as other mk3 polo's?
1 of my bushes are gone so i thought i would just replace the whole arm for easyness.
phoned vw and they said they were £85 +vat per side, so i phoned my local motor factors place and the quoted me £25,
is there any differance between polo's? cheers
mark
Title: Re: bottom arms?
Post by: PeteG40 on April 21, 2010, 10:15:30 AM
g40s have an inner rose joint
Post by: grayg40 on April 22, 2010, 09:10:02 AM
would a non G40 one do the job as they look nearly identical. i know the bushes are not as tight but would it do?
Post by: G-spot on April 22, 2010, 09:18:11 AM
No
if your gonna fit non G40 one's then I'd change the pair, but be prepared for less responsive suspension/steering( a sacrifice I wouldn't make)
Alternatively if the outer bush only has gone then you could fit uprated powerflex ones.
Are you sure that your G has still got the OEM rose jointed ones fitted??
Post by: PeteG40 on April 22, 2010, 09:24:15 AM
As jason said.  They fit, but aint as good!
Post by: grayg40 on April 22, 2010, 10:14:38 AM
cheers, my inside bush has gone (opposite ball joint) but vw can supply them so just going to press in a new bush rather than the whole arm.
where's the best place to get power flex bushes from?
Post by: cheddarcheese on April 22, 2010, 03:29:39 PM
try philJ for bushes http://www.clubpolo.co.uk/forum/index.php?showtopic=192873
