Technical => Engine and Transmission => Topic started by: Ratty Pete on March 31, 2010, 10:10:47 PM
Title: Breaking cv joints
Post by: Ratty Pete on March 31, 2010, 10:10:47 PM
Hello, i have just got myself a 'L' reg polo with a g40 engine fitted... The car wasn't running when i got it as the conversion wasn't finished, so i'm not 100% whats been done/changed... the gearbox is a five speed and the car has been lowered. Anyway the problem is that i have broken 2 cv's in the 4 days its been on the road!!!! Its been the inner cv on the longer drive shaft both times! Any ideas anyone? I was wondering if the the drive shaft is two short causing the cv to be streched? are there different ones on the standard car? oh yeah the first time i was excelerating hard the second time i was just taking it steady going around a round about..
I've been into aircooled vw's for the last 10 years, this is my first water cooled so this is all new to me. Thanks for your help.
Title: Re: Breaking cv joints
Post by: cheys03 on March 31, 2010, 10:35:26 PM
Quote from: Ratty Pete on March 31, 2010, 10:10:47 PM
Sounds exactly the case. You've probably got an early gearbox (ATV?) with late (L reg) offside drive shaft which is shorter than early (H-K reg?) driveshafts.
There are two options - source the longer early driveshaft (preferably a G40 or uprated item) or change the offside output flange on the gearbox to one from a late gearbox (it's longer).
I've no direct experience of this though, I'm only going on what I've read here on the forum.
Post by: Nick_S on March 31, 2010, 11:42:31 PM
Yep. If your just putting new CV's on the original L-reg polo driveshaft it won't cure the problem, as the late ones are about 10mm shorter. Easiest thing to do is get a complete offside driveshaft assembly off a H or J-reg mk3 polo.
Post by: Ratty Pete on April 01, 2010, 07:34:51 PM
Thanks for your reply's... I know you will all probably cringe but i got a mrk 2 golf shaft and cut and welded it to make it 10-13mm longer than the one on the car... i've taken the car out and down the motorway, seems ok and no vibrations.. but i'll prob source one that fits properly... i love the car and just want to get some confidents back in it... thanks again!!
