Technical => Superchargers / G-Lader => Topic started by: Oily Fingers on February 20, 2010, 10:20:07 PM
Title: Pulley Set up Eaton!
Post by: Oily Fingers on February 20, 2010, 10:20:07 PM
Hello, right, just bought myself an Eaton charger kit, with cam, PSD 1341cc chip, tappets and toothed belt and all the pulleys and tensioner, and the PSD ali bracket.
has anyone got a pic of the set up of the belt fully assmebled on the engine with the pulleys etc?? just tring to get my head round it atm.
cheers Joel
Title: Re: Pulley Set up Eaton!
Post by: poloeatonm45 on February 21, 2010, 05:56:51 PM
i have an eaton set up but its a home brew kit so cant help you with the pully set up
steve
Post by: vwmk3jon on February 21, 2010, 08:27:11 PM
Joel,
Ive got the charger off at the mo but its easy enough to route the belt. I could try and do you a bit of a diagram to show you now?
Also, if you have a PSD eaton kit, you want to check the pulley seals not leaking before you put it on as its £30 for 250ml of oil off ebay!
Post by: vwmk3jon on February 21, 2010, 09:07:42 PM
(http://i965.photobucket.com/albums/ae140/jonjong40/IMG_0314.jpg)
Belt runs to left of bottom tensioner, round pulley and then the top tensioner is adjusted to remove any slack. If theres still lots of slack, you'll need to adjust the bottom tensioner by undoing the bolt and adjusting it accordingly. I run a 1150mm belt btw.
hth.
Jon.
(i can get you some pics of the pulleys on the engine if you need them?)
Post by: PeteG40 on February 21, 2010, 09:57:22 PM
btw club g40 stocks 1120 toothed belts for eatons
Post by: vwmk3jon on February 21, 2010, 11:20:48 PM
I had a 1120 belt on originally pete but the one you sold me fits more snugly.
Post by: PeteG40 on February 21, 2010, 11:23:58 PM
it was a 1120 i sold u!
Post by: vwmk3jon on February 23, 2010, 02:24:27 PM
Ah ha, yes i remember now! This one fits more snugly than the diesel cambelt that was on there anyway!
