Technical => Turbochargers => Topic started by: LeonL on February 14, 2010, 08:50:05 AM
Title: K03 Shaft Play...
Post by: LeonL on February 14, 2010, 08:50:05 AM
Hi,
If a k03 turbo has play in the shaft will a service/rebuild fix the problem?
What causes play in the shaft?
Title: Re: K03 Shaft Play...
Post by: Tommo on February 14, 2010, 10:58:41 AM
It depends what you mean by 'play'. Most turbo's use journal bearings which are designed to have a fair bit of gobble in them, this space is taken up by pressurised oil so that the whole system floats. About 1mm radial clearance is perfectly acceptable, and it has to be double that before it effects the turbos operation much. Axial clearence should be considerably less, you shouldnt be able to detect much of that.
Post by: LeonL on February 14, 2010, 11:06:09 AM
Well the guy who owns the turbo said,
"slight movement in the shaft no fins damaged would advice a rebuild to get rid of the movement in the shaft"
Just working out if its worth buying
Post by: hayesey on February 14, 2010, 11:20:30 AM
well like tommo said you will get a small amount of radial movement when there's no oil pressure in the bearings.  So it depends what type of movement he means and how much there is.
Post by: dub-disaster on February 14, 2010, 11:21:42 AM
Probably not as a rebuild on a turbo is more costly than buying a second hand k03 or even a cheap Chinese copy !
Post by: Tommo on February 14, 2010, 11:07:00 PM
I would rather run a knackered genuine one than a chinese copy. Poor performance from them and it will make a right mess if it ever lets go, which it is more likely to do due to poor material quality.
Post by: dub-disaster on February 15, 2010, 10:07:46 AM
I'll bear that in mind if I ever have to replace my turbo
Post by: Tommo on February 15, 2010, 06:27:49 PM
Whenever you buy a turbo always check its genuine, I really cant express how much work goes into making the things perform well and hold together. And the chinese just reproduce somthing that looks about the same.
This is worth watching, although its the americanised version which drives me nuts...
http://www.youtube.com/watch#playnext=1&playnext_from=TL&videos=eKK-O6C9NAY&v=Za0DieZHMKc
Post by: dub-disaster on February 15, 2010, 06:32:14 PM
Dunno if it's just me but dnt think the link works
Post by: LeonL on February 15, 2010, 06:58:38 PM
Quote from: dub-disaster on February 15, 2010, 06:32:14 PM
Worked for me
Post by: hayesey on February 15, 2010, 07:13:00 PM
works ok for me too.  quite a good video except for the ridiculous accent !
Post by: dub-disaster on February 15, 2010, 07:55:25 PM
Trying to watch it on my phone I think that maybe why t dun work
Post by: Tommo on February 15, 2010, 09:09:40 PM
Quote from: hayesey on February 15, 2010, 07:13:00 PM
I hate the bloody voice over. Especially the bit with the school bus where they are practically saying if you buy a fake turbo then your kids will die.
Reminds me of that car add off the simpsons where it says "if you buy an import car you are taking food of an american familys table" haha
Post by: GAF2 on February 15, 2010, 10:49:15 PM
we have cummings engines with holset turbo's on our fleet of diesel trains and never get any problems with the turbos, unlike newer merc built engines.
Post by: Tommo on February 15, 2010, 11:06:34 PM
Sweet! I will pass on the good feedback lol.
