hiya all
1 last question lol, i am losing brake fluid slowly over say 2 weeks from max to min that is, i have still got a perfect pedal dosent sink, i have checked all my unions, flexis, nipples b/pipes the lot no leaks, all i can think is its possibly leaking in to the brake servo from the master cylinder???. any one ever had awt like this atal lol, any help pleas thnx boyzey
Yeah mate i have just had this problem. I checked all lines and brakes etc, same as you then it lead to my o/s rear wheel cyclinder. It was pretty much pissing out fluid and i was topping up fluid every few weeks. Will prob be them. Not expensive to replace.
have had all drums off n cylinders ar fine, have checked all brake lines n also fine,
but rae u say if it is the servo that leaks it ends up getting burnt ye, because my plugs ar black and i only put them in bout month ago, is it possible that the fluid goes down vacume from the servo then and eventualy in to engin
thanx for all help
oryt yep that culd all make sence now m8 thanx allot,
lets say it is my servo i dont supose u no if the servo off my 1 litre polo will be the same do ya, or if they are specific to the g40,
thanx again great help buddy
What year is your 1.0 polo?
I think all mk3's are the same.
both my 1 litre and my g are 1993 m8. i looked in haynes manual but it dosent mention that they are different ???,
if any 1 does no culd they possibly tell me if the master cylinder is the same 2 as i will swap them both over if so and play it safe haha
cheers boyzey
Use this,
http://www.vagcat.com/
It is very handy. I have been using this for about a year now. When i went on and looked they were the same.
http://www.vagcat.com/epc/cat/vw/PO/1993/120/54/1254553/
Here is a direct link. It depends as there are two types,
tandem master cylinder / for models with no brake servo
And
tandem master cylinder / for models with brake servo
Have a look and see what you think.
nice one m8 thanks allot i will take a look cheers,
but if any boddy wants to confirm for sure i wuld apriciate that
thanx again buddy
All RHD mk3 Polo's have the same servo.
You need to order a tandem master for use with a servo. Shimples! ;D
oryt nyce 1 well lyk i say i gt servo n master cylinder sat on the drive duing nothing in my 1 litre so i will jst swap them ova at weekend
yep you was right rae my servo was full ov brake fluid haha thanx allot 4 pointing me in the right direction chears
ha i had this problem too, annoyed me no end!
and cleaning the servo out, jesus thats a hard task too
yes i can imagin lol that is way ill be using the survo and master cylinder ofav my red polo haha. the servo was well and trully full of brake fluid it weighd a tone lol, only been leaking 4 like 2 week haha uwwwwp, but ye thanx again alll great help
