As above, are they G40 specific, or just early/late spec? so if I was to get another 1992 K year loom it would be the same as mine currently fitted?
which bit?
there is a dash loom
a plug int to the dash loom for the stereo/fag lighter
front to back for fuel pumps
plug into front to back for rear lights.
Dash loom really, taking out the dash, and want to either remove the alarm, or wire it in a bit neater behind the dash!
they are but
1. saloons dont have a rear wash wipe
2. the clip in stereo loom is different in poverty spec cars
do GTs and G40 not have the extra wire for the water header tank level warning light? or is it already in like the rev counter wire?
watch rear wiring looms too as there are 2 types of inline pump connector if your cars a conversion.
wiring to header tank is not a spec, but an age thing i think.
and rich's right, there are mpi and non mpi fuel pump plugs, but strangely late spec ones tend to have non mpi, but with a mpi pump - like they standardised the wiring but offered mpi/nonmpi pumps with the same plug if that make sense.
