Technical => Engine and Transmission => Topic started by: vwmk3jon on November 04, 2009, 07:04:47 PM
Title: Aquamist questions
Post by: vwmk3jon on November 04, 2009, 07:04:47 PM
Need to buy some vacuum hosing and high pressure poly tubing for my kit.
Where'd be the best place to buy it from?
How do you measure the nozzle size and what would be the best size to use?
The nozzle goes into the boost pipes after the intercooler. Am i best of drilling a hole into my boost pipe (its metal) and screwing the nozzle in?
Title: Re: Aquamist questions
Post by: hayesey on November 04, 2009, 07:18:04 PM
ERL (aquamist) sell nylon tubing which is what I use with mine, since it's an ERL kit anyway.
You can also get the nozzles from ERL, 0.3mm is what people tend to use on g40s.
Yeah screwing it into a hole drilled into a solid pipe is the best bet.  If you use an ERL nozzle you need to get an m8x0.75mm thread tap which can be bought from ERL again or off ebay.
Post by: vwmk3jon on November 04, 2009, 07:52:59 PM
Mines a coolingmist kit so not really a proper aquamist kit (but does the same thing).
You think the nozzles will be the same? I got 3 nozzles with mine but have no idea what size each one is!
Post by: vwmk3jon on November 05, 2009, 02:53:40 PM
Looks as though the kit is from here: http://www.coolingmist.com/pagedisplay.aspx?feature_key=parts
Post by: dub-disaster on November 05, 2009, 03:06:55 PM
is the cooling mist kit just as good as the aqumist kit as its a damn sight cheaper and includes a tank !! or is the aquamist alot better kit ??
Post by: vwmk3jon on November 05, 2009, 07:19:11 PM
I cant give you an answer on that as i got my kit pretty cheap off ebay! I didnt get a tank though so need to find one (preferably a shiny one).
Post by: dub-disaster on November 05, 2009, 09:32:02 PM
i got a shiny tank for sale in the classifieds at the moment!! have a look, let me know how it works out cause this kit is cheeeaaap!!
Post by: vwmk3jon on November 05, 2009, 09:52:00 PM
Mine was well cheap - £120  ;D
i'll have a looksie at the tank and let you know.
Post by: vwmk3jon on November 06, 2009, 12:01:44 AM
will silicone pipe be affected by methanol?
Post by: vwmk3jon on November 06, 2009, 10:41:07 PM
...and am i right in thinking the boost valve cotrol thing would be best off being inserted into the pipe from the ECU?
Post by: hayesey on November 07, 2009, 11:50:22 AM
no dont put anythign in the pipe to the map sensor
Post by: supercharged spaniel on November 07, 2009, 02:33:48 PM
someone explain aquamist on a g40 pleeeease  :)
Post by: lance on November 07, 2009, 05:51:44 PM
it squirts a fine mist of water into your boost to lower charge temps to save your engine from heat mainly for saving your valves, once mixed with methonal it gives you peformance advantages.
Post by: supercharged spaniel on November 07, 2009, 05:53:57 PM
interesting...thanks :D
Post by: hayesey on November 08, 2009, 03:51:20 PM
it's a good way of suppressing detonation, the methanol burns slowly and in a controlled manner meaning that you can have more ignition advance with high boost and hence more power.  And it also reduces inlet temps too.
Post by: vwmk3jon on November 08, 2009, 04:43:40 PM
Quote from: hayesey on November 07, 2009, 11:50:22 AM
Ah, ok. I'm slowly working out how to install it (instructions are confusing!), just lot on afew things......
Where does the boost control valve plumb in?
flow of pump (which is inlet & outlet)
flow of filter (isnt the same as shown in instructions!!)
Post by: vwmk3jon on November 08, 2009, 05:29:23 PM
Make it abit easier......
(http://i965.photobucket.com/albums/ae140/jonjong40/IMG_0865.jpg)
Inline filter. I know it goes between the tank and the pump but which way round?
(http://i965.photobucket.com/albums/ae140/jonjong40/IMG_0866.jpg)
pressure switch? I'm unsure if i need this and if i do, how it wires in as all the wiring i have i've accounted for
(http://i965.photobucket.com/albums/ae140/jonjong40/IMG_0867.jpg)
all the wiring labelled :)
Post by: hayesey on November 09, 2009, 09:35:02 AM
did the kit not come with any instructions?  Not sure how much help I can give really, I know how my ERL Aquamist kit goes together but this one is different.  The ERL kit comes with a proper loom with connectors and full instructions.
You'll need the pressure switch though, that's what actually actives the aquamist, otherwise it'd either be on constantly or never on at all.
Post by: vwmk3jon on November 09, 2009, 01:24:23 PM
I've downloaded the instructions but they're not very clear at all!
I'll have a play around with the bits and see what happens.
Post by: hayesey on November 09, 2009, 02:15:58 PM
do you have a link for the instructions?
Post by: PeteG40 on November 09, 2009, 02:24:25 PM
Quote from: vwmk3jon on November 09, 2009, 01:24:23 PM
LOL - sounds like a kid playing with matches...
Post by: vwmk3jon on November 09, 2009, 02:42:56 PM
i'm not that bad! (am i?)
unless im blind (quite possible), i cant find no mention of the pressure switch so unsure where it goes and not sure of the flow of the pump and filter as the filters different to the one shown in the instructions and neither had any markings on to show this.
Instructions are in PDF format. I'll find a linky......
Post by: PeteG40 on November 09, 2009, 02:44:04 PM
pressure switch should act like and on/off switch for the pump so it only switches on at decent boost levels.
Post by: vwmk3jon on November 09, 2009, 02:44:15 PM
http://www.coolingmist.com/instructions/standardkitinstructions.pdf
Post by: vwmk3jon on November 09, 2009, 02:46:47 PM
Quote from: PeteG40 on November 09, 2009, 02:44:04 PM
So i'd assume it goes before the pump?
Been looking at install pics online to try and work out where stuff goes.
wiring to boost switch, pump and connected relay is sorted. Its just the damn pressure switch (although i do have an idea......)
Post by: vwmk3jon on November 09, 2009, 09:24:03 PM
dumb moment yet again!
Looking for pipe and found this on fleabay. Looks the same as what i have. Is it any good?
http://cgi.ebay.co.uk/Pneumatic-airline-tubing-pipe-6mm-nylon-blue-colour_W0QQitemZ110275126218QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item19ace8e3ca
Post by: hayesey on November 10, 2009, 05:28:20 PM
page five tells you what to do with the boost switch, although the one in your pic doesn't look like the one in the instructions.
Post by: vwmk3jon on November 10, 2009, 11:43:19 PM
Thats what i thought!
Well the worst that can happen is i wire it in and it doesnt work in which case im sure it'll be the case of swapping afew wires round.
May have a look tomorrow, depending on when i get home/weather/how tired i am!
Post by: Dirty Slag on November 12, 2009, 11:24:45 AM
Worst case it can fill your engine with water and totally screw it up!
Why even bother with this stuff aqau mist/methanol is normally used on mega high boost applications unless your running over 200bhp you may as well just get a bigger fmic so much easier to fit and no water or wiring to screw up and prob cheaper!
Post by: vwmk3jon on November 12, 2009, 02:12:02 PM
I'll obviously test the kit before final fitment.
My FMIC is quite big already (AWT item)
Post by: Dirty Slag on November 12, 2009, 02:21:15 PM
What are your charge temps?
Unless they are dangerously high then its a bit pointless fitting it!
Post by: PeteG40 on November 12, 2009, 02:33:12 PM
aquamist makes a decent benefit to forced induction. Paul borthwicks 1272cc saw something like 15-20 bhp from a flowed head and aquamist and said the water injection was noticeable on the road.
and you should see the benefit with an eaton as they run really high temps as they are inefficent compared to a g charger.
Post by: hayesey on November 13, 2009, 07:22:44 PM
Mr slag, not being funny but aquamist DOES work on these cars.  I know the theory, I know what it does and I know how it works.  But you can talk about theory till you are blue in the face, the fact is we've proven that it does what we expect on a dyno, without it you need to either back off ignition advance and/or reduce boost pressure, both of which cause a loss in power.  With aquamist on with a 50/50 mix of water & methanol more power can be achieved, I'm not just saying what I think or what should happen but what we've actually done, in real life, on a real dyno.  I appreciate that you are a knowledgable guy and that you hav years of experience but please, please just stop trying to tell us that we're all wrong about everything, it's starting to annoy me.  Be more open minded.
Post by: vwmk3jon on November 14, 2009, 08:47:54 PM
Mr slag  :D
Got it 90% worked out:
Tank ---> filter ---> pump ---> acctuator ---> injector.
Boost switch into pipe from TB and wires to pump and ground.
Sound right?
cheers for all the help/info btw ;)
Post by: Robin on November 14, 2009, 08:57:51 PM
Mr Slag you really are coming across as a complete cock!
This forum doesn't need people like you here.
