Technical => Engine and Transmission => Topic started by: nikky on October 19, 2009, 08:50:28 PM
Title: what bottom end?
Post by: nikky on October 19, 2009, 08:50:28 PM
hey all
what bottom end fits on the g40 head and box,looking for a bigger block 8)
Title: Re: what bottom end?
Post by: Varley on October 20, 2009, 12:48:04 AM
You can use the block and crank from either a SEAT terra diesel van or a diesel polo from the continent, engine code 1W.
Not the easiest to find in the uk but you'll get 1473cc...
Also benefits from oil squirters under the piston skirt for better cooling.
Post by: Justin14100 on October 20, 2009, 08:57:13 PM
Quote from: Varley on October 20, 2009, 12:48:04 AM
I have read about those oil squirters before, sounds very complicated; how does one do that?
Post by: Varley on October 20, 2009, 11:38:15 PM
Not so much something you 'do' more of a design feature.
Route for oil to 'squirt' up from holes in crankcase to underside of piston. G60 engines had them as standard, a G40 did not. Think it's standard procedure on newer engines.
