Technical => Superchargers / G-Lader => Topic started by: liam on October 18, 2009, 07:58:12 PM
Title: stage r1 charger
Post by: liam on October 18, 2009, 07:58:12 PM
does anyone have an idea of what boost my g40 charger should be pushing out?
its just had a stage r1 rebuild and upgrade with jabba induction kit,
65mm pulley toothed belt conversion, im running g60 injectors with the ecu chip to suit them, amonst many other mods.
Title: Re: stage r1 charger
Post by: PeteG40 on October 18, 2009, 08:06:25 PM
on a stock head and inlet - about 1 bar
Post by: liam on October 18, 2009, 08:16:45 PM
the head has been totally stripped down, rebuilt and ported and polished and the g40 inlet manifold has been port matched would that make any difference.
Post by: hayesey on October 18, 2009, 09:37:05 PM
will make a slight difference.  with stock head and inlet would be just over a bar, with gt inlet and head work it'll be just under a bar.  so I guess yours should be somewhere between the two.
Post by: PeteG40 on October 18, 2009, 09:37:19 PM
might drop it slightly, but i'd say 0.8 bar minimum
Post by: liam on October 18, 2009, 09:57:37 PM
nice one lads, always helpfull. ;D
Post by: SuperMario on October 19, 2009, 06:08:57 PM
1bar in psi?
Post by: GAF2 on October 19, 2009, 07:09:56 PM
bout 14psi i think
Post by: hayesey on October 19, 2009, 07:47:37 PM
1bar = 14.5psi
Post by: Shailan on October 20, 2009, 12:13:31 AM
should be around 12psi with head ported
