Does anyone know the correct procedure for removing the standard intercooler? I havn't checked it out on the car. Ive had a look through haynes but theres nothing in there. is it straight forward to remove?
My plan is to clean it up a bit (remove the flies) and straighten out the fins.
John
Just the case of undoing a couple of bolts iirc and undoing and removing the boost pipes. Easy to do. I put mine in a bucket of soapy water to remove the oily buildup and then rinsed in well and left it to dry for a couple of hours.
managed to get it off yesturday without complication apart from a rounded off nut which was very annoying! I've straightned out most of the fins now. Next im takin it up the jet wash to blast out all the gunk
use carb spray to clean the inside
