I know you can get g60 mounts from g-ladersiete or make yr own, but what belt kits have people used - or know about???
g60s use ribbed belts - can crank/alt pulleys be used from a mk4 polo or something? similar size/fitting to a g40?
You can buy on ebay.de kit for G60 in Polo with pulleys and belt (5/6 pk) or tooth pulleys
http://cgi.ebay.de/G60-Lader-kit-im-Polo-G40-jetzt-mit-Flansch-Ladeluftrue_W0QQitemZ190334407501QQcmdZViewItemQQptZAutoteile_Zubeh%C3%B6r?hash=item2c50d0934d&_trksid=p3286.c0.m14#ht_575wt_732
Ask him for price without chip, spark plugs etc
I was thinking I could get a toothed charger pulley made up to work with PSD toothed crank/alternator pulleys?
Doubt it'd be cheapest option though!
Use standard pulleys/belts from G40 in G60 lader, this would be the cheapest option
If the toothed pulley from a PSD kit or G-werks kit doesn't work, I'm sure it would be easy to get another pulley sorted for that type of belt. Give me a shout if you decide to go this route as I might be able to help.
