Technical => Engine and Transmission => Topic started by: Jezza-7 on September 30, 2009, 01:09:20 AM
Title: What type of timing belt
Post by: Jezza-7 on September 30, 2009, 01:09:20 AM
Have seen two different types, one with 108 teeth and the other with 128
Which one would suit a 92 G?
Title: Re: What type of timing belt
Post by: hayesey on September 30, 2009, 09:35:25 AM
more than likely the 128 tooth belt (normally called a round toothed belt).  The other one is normally on older polos and has square teeth.  A 1992 polo should have the round one but the only real way of telling is by looking at it.
Post by: Jezza-7 on September 30, 2009, 09:37:33 AM
Ah ok, thankyou!
Post by: Alexiskayak_7 on September 30, 2009, 11:45:55 PM
If you tell at the seller the chasis number, he will tell you exactly what type of belt you have
Post by: hayesey on October 01, 2009, 12:21:15 PM
you can tell from the engine number too, I think ETKA/vagcat shows the ranges of numbers for each belt.
