hi ive got a secd of mk2 golf 16v front disks and calipers, these are 256mm disk. what do i need to make them fit to my g40?. can i run these calipers or do i have to change them?
thanks
darren
You can run the calipers, but you need a pair of pad carriers from an old audi 5 cyl coupe.
you can get vauxhall 256 redtop valva ones for £20 and they fit plus there better.
do you mean just the pad carriers off a redtop?
no he means the calipers, but if u get the calipers what caliper carriers do u need standard polo mk 3 ones vaxhall redtop ones or the audi 80 quattro ones??
Quote from: lance on September 30, 2009, 10:46:11 PM
what makes them better out of interest?
Quote from: hayesey on October 01, 2009, 12:22:18 PM
Better?? or just a hell of a lot easier to come by??
the piston is bigger in the vauxhall ones.
yeah what carriers can i use with redtop calipers?? ???
again i second that what caliper carriers for redtop vaxhall calipers does any one know where to getg some redtop vaxhall calipers from new and or used??
you use the red top calipers but buy different bolts for them. people sell the bolts on clubpolo,
you can buy the callipers and that from any scrap yard/breakers.
ok make this real simple for me cause other wise ill get it wrong! wich model car do i need to get calipers and carriers from ? and then i need m12 sholder bolts from club polo?? Too make it real basic for me what do i need to buy for the conversion write me a shopping list if any one can and where to get from would be a great help :) thanks guys
you need calipers and carriers from a :-
astra mk2 GTE 16v
cav GSI or SRI 16v 1991 on
astra mk3 GSI 1991 to 1996
maybe others ill ask my mate he is a vauxhall nut.
these.
http://cgi.ebay.co.uk/astra-gte-16v-calipers-and-disc-brakes_W0QQitemZ270462134202QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ef8cca7ba&_trksid=p3286.c0.m14
disks for a mk2 golf 256mm gti.
yea the shoulder bolts from club polo.
if you wanted to you could fit 280's from a cav turbo or calibra turbo with G60 disks i think.
This sounds interesting! Supid question! Will they fit with the original 13" wheels or does one need to go to 14" or more?
depends on the wheels may fit under 13's but its hard to say all depends on the setup!
unless you have some really fancy 13's they wont go under them.
what about the servo and master cylinder? keep the G40 one or upgrade?
id go with a golf mk2 16v master.
again should be fairly easy to get hold of i would of thought, have really been contenplating this for a while, however every time i tweak the rear drums up and adjust the hand brake i think the brakes are amazing again (well as amazing as they will ever get).
i have 4 pot 300mm hi specs on the front and golf gti mk4 rear calipers/disks on the back and they are still not amazing :D
Quote from: lance on October 02, 2009, 04:15:48 PM
Hahahaha, I reckon you just drive to fast :-) only issue I have is that my mate has my 14's and I have his 13's, after a short conversation I don't think he wants to swap back lol.
you'll be surprised what a difference good disks and pads make! so you can stick with your 239's.
Oh yes dont get me wrong i have good dics and pads, braided hoses dot 5:1 fluid and all new rear drums/shoes etc spent a lot on it all but a great improvement i think, just need to tweak the handbrake again as i have done 500 since all the new stuff but still i think they work well.
i got sum shoulder bolts if ne1 needs sum
