Technical => Exterior and Interior => Topic started by: Jezza-7 on September 08, 2009, 01:43:59 AM
Title: Water in boot
Post by: Jezza-7 on September 08, 2009, 01:43:59 AM
After some rain last night, i noticed that my jumper in the boot was very wet and guessed i have a leak. Anyone had a similar problem or know what could cause this?
The boot seal does look ok.
Title: Re: Water in boot
Post by: Jezza-7 on September 08, 2009, 01:55:46 PM
I shall do that with the hose pipe. It seems to come from the left corner so i will keep an eye out around the light. Cheers!
Post by: Jezza-7 on September 10, 2009, 01:20:09 AM
Found where it is coming from. It is coming from the left hand side of the boot, will take a pic to show where i mean. Hopefully get the bumper off and i will see something, like a hole??? Some silicone should fill up the hole.
Post by: SpikeyG40 on September 24, 2009, 03:18:32 PM
I have a leak in my boot but i'm pretty convinced its the bee sting arieal.  Its certainly seen better days.   Got the repair kit, but it looks like a right 'mare of a job to change.   peeling back the roof lining round the boot is going to be the first issue.  I made a start but the stuff has gone really brittle.
Post by: PeteG40 on September 24, 2009, 03:27:25 PM
you can often pick the base washer apart from the top and then put the new washer in boiling water and fit from the top!
Post by: projectg40 on September 24, 2009, 08:59:32 PM
iv had the same problem with the arial . i picked the old washer away and then bottled out pulling the roof lining back,  but i will try the hot water washer method !! great  help  cheers peteg40 ( hope it works ) :P
Post by: SpikeyG40 on September 25, 2009, 12:35:20 PM
Thats good advise! Thanks, i think i'lll give it a go.
Is there not another small o-ring further down that might need changing?   I've done one on a mk4 polo before and seem to remember another o-ring.  That was a peice of piss to do on that though.
Post by: Justin14100 on September 26, 2009, 11:10:47 PM
Anyone got the part number for the repair kit?
cant find it on etka!
Thanks!
Post by: PeteG40 on September 26, 2009, 11:25:48 PM
http://cgi.ebay.co.uk/VW-Golf-Passat-Polo-GTI-Roof-Aerial-Rubber-Gasket-Seal_W0QQitemZ360192024671QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item53dd1e205f&_trksid=p3286.c0.m14
these aren't bad!
Post by: Jezza-7 on October 25, 2009, 05:28:51 PM
Off came the bumper and could see a slight split of where possibly the weld had slighty come apart i beleive. Put some black silicone along it, then it rained all friday night but in the morning no water in boot.
