Hi,
Just wondering what would cause the G40 to run rich on start up. Idles at above 1k revs when starting the car from cold, sometimes revs up and down a little under its own free will and then after a short time the car idles fine(im assuming once it has warmed up). I can smell petrol on start up as well, also indicating the car is running rich right? Other then this the engine runs smooth and doesnt seem to have any problems...
Any ideas?
Leon
Possibly the blue temp sensor. I assume you have been through everything on the diagnostic guide.
Thinking about it, it could just be normal. They are a bit richer on a cold start map. Although it shouldn't smell too much of petrol.
Part number for blue temp switch and were can i get a replacement?
VW Dealers. Don't accept imitations!
hell dont accept vw either, i got a vag one and it was as shit as the gsf one
best bet is to scrap yard grab a load...
At least if you go to VW you can send it back and get another, which is more than GSF's policy on electrical parts.
Part number anyone? I'll get on the case and get one asap
Also any ideas on the price?
it's about a tenner, no idea of the part number just ask for a blue temp sender for a mk3 polo g40 and they'll find it no probs.
Not to bad then, cheers...
I'll get onto it at the weekend :)
Problem after problem these g40's are ;)
All the blue temp. se4nsors on the MK3 Polos are the same, so... It's not necessary to say G40, just ask for MK3 Polo ;)
But I think it's normal to run rich when it's cold. Before some time I've red a russian book for the gasoline engines and there was wrote why when the engine is cold the AFR is rich. So... I think You've got no problem. ;) Mine is running rich when it's cold too and I know all is OK. :)
yeah but it shouldn't be running overly rich on cold start cycle. Always best to change the blue CTS.
Just a little update,
Went into VW with the blue temp part number i found in another topic(VagCat part number for 1991 G40 model), also took the part number i found on VagCat for the 1994 model G40 which was slightly different to the 1991 number.
They said the part number for the 1991 blue temp sensor didnt exist anymore but the 1994 one i supplied did.
Either way ordered the sensor and part number for anyone who needs it is: 025 906 O41A
is it not the fact that the chokes on?! i wouldn't let it worry you mate...
it will start up rich anyway every engine does that till the engine is at right temp to run smoothy at idle.
Yeah but its abit more then that, it doesnt just hold a little over the revs. Its about jumpy, up and down when you hold the revs etc...
