Technical => Electrical => Topic started by: PeteG40 on June 27, 2009, 05:42:59 PM
Title: whiney fuel pump and i've changed it!!!!.. and lift pump...
Post by: PeteG40 on June 27, 2009, 05:42:59 PM
right, fuel pump started to whines like an RC car, so got  a second hand one off dan barnes and swapped it. I also cleaned the filter on the intank pump.
It still whines!!!
what do people reckon it is???  fuel filter need changing?
Title: Re: whiney fuel pump and i've changed it!!!!
Post by: scotsjohn on June 27, 2009, 06:12:09 PM
A safe bet Pete, but what sort of mileage on it? My first filter change was at 165k on my old G.
Post by: hayesey on June 27, 2009, 06:25:05 PM
what about the lift pump?  If that's worn out maybe the inline one is struggling
Post by: dannyb.G40 on June 27, 2009, 09:07:24 PM
i changed the inline one and it didn't fix anything, turned out to be the lift pump as hayesey said
Post by: PeteG40 on June 28, 2009, 11:31:20 AM
fuel filter has been replaced and looks quite new. I shall investigate the lift pump. It only does it on occasions, but embarrassing at the very least at traffic lights!
Title: Re: whiney fuel pump and i've changed it!!!!.. and lift pump...
Post by: PeteG40 on June 28, 2009, 06:17:54 PM
right, changed lift pump and it still whines.
I'll change the filter tomorrow... but other than than, what can it be??? would a dodgy FPR cause the pump to overwork? it does seem to get warm when whiiiiiiiiiiiiiiiiiirrrrrrrrrrrrrrrrring and whining
Post by: scotsjohn on June 28, 2009, 06:36:58 PM
Any chance of a kink or crimp in the fuel line while doing other work? Return pipe blockage?
Post by: PeteG40 on June 28, 2009, 09:33:24 PM
i'll check connections in the engine bay... its weird as its only really bad stood/at idle.
1. Pipes in engine bay
2. fuel pressure reg
3. fuel filter
hopefully get to the bottom of it!
Post by: scotsjohn on June 28, 2009, 09:42:47 PM
At it's worst with least demand; starts to sound like the regulator.
Post by: PeteG40 on June 29, 2009, 09:51:32 AM
i've got a few regs about... will check pipes and reg tonight..
fingers crossed will get to the bottom of this.
Post by: PeteG40 on June 30, 2009, 06:14:49 PM
pipes seem ok, regulator changed... now seems to behave... but  not had a good test. Will test and report back.
pete
Post by: Dan on June 30, 2009, 07:12:15 PM
Interesting that regs do that. Not heard it happen before, but would make sense.
Post by: PeteG40 on June 30, 2009, 07:38:12 PM
only thing i can think is that the reg wasn't letting it return to the tank and therefore backing up and straining the pump
