Mine is making some comical noises, i suspect the motor is on the way out. Anybody know whether vdub fitted the same fan to other polo/golfs? I reckon a trip down the breakers is in order.
Cheers!
it's a two speed fan on a g40, GTs also have them but I don't think any other models did. I could be wrong though!
ah bugger that narrows it down a little. hohum if i have to go to the stealers......
probably be cheaper to replace it with an aftermarket slimline fan!
2-speeds were fitted to lesser models too, my CL has one.
I had a feeling that might be the case, hence my initial "I could be wrong" statement :)
In typical VW of Spain style it'll probably be totally random! You'll be able to tell because a twin speed has a 3 pin connector and a single speed has a two pin one.
It has been know for GT's to come with single speed fans, my blue one did. Like Hayesey said, just look for the 3 pin connector plug and your sorted.
ah o.k so i will go down the breakers and have a mooch about.
heysey these slimline fans you talk of sounds good have you bought one can you recommend any, I will have to go investigate.
thanks guys for the advice!
