what vacuum pipes does the g40 need to run smooth and what dont you need and can be bunged up and what pipes goes where? inc ecu vacuum pipe?
andy
All i have is large vacuum pipe to the brake servo then a small pipe to fuel pressure regulator and one to ecu.
Both of the smaller pipes come out of the servo pipe underneath where the throttle body hose is.
Hope this helps.
Rob
