Technical => Engine and Transmission => Topic started by: G40_FUNK on May 08, 2008, 08:20:31 PM
Title: Best Plugs and oil
Post by: G40_FUNK on May 08, 2008, 08:20:31 PM
Ok, im going to get my G serviced and that lamda probe looked into.  Thanks for all the helpful advice from members of this site.  I take it the best oil is quantum semi synthetic?  Im at a bit of a loss plugswise though!? There is a guy selling them on ebay, but are they the right type for a g40?
http://cgi.ebay.co.uk/BOSCH-SUPER4-SUPER-4-SPARK-PLUGS-POLO-COUPE-1-3-G40_W0QQitemZ370048111929QQihZ024QQcategoryZ9889QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Title: Re: Best Plugs and oil
Post by: PeteG40 on May 08, 2008, 08:24:05 PM
w5dpo bosch
Title: Re: Re: Best Plugs and oil
Post by: hayesey on May 09, 2008, 09:49:32 AM
no those aren't the right type in that ebay listing.  As Pete says, Bosch W5DPO (although I think they've been superceeded by part number something like WR5DP nowadays which is the same thing but with a resistor in it).  They are single electrode plugs with a platinum tip, cheaper ones will run too hot.  You can get away with cheaper ones in a standard g but it still wont do power any good.
Post by: vwmk3jon on October 10, 2008, 10:21:03 PM
ive just put some in i got from GSF. Not the W5DPO code but W5DTC or something like that. These rubbish? I had to change them badly as the ones i had in there were knackered!
What about using W4DPO's ?
Post by: PeteG40 on October 10, 2008, 11:58:59 PM
w5rdpo (same as orig but with resistor have replaced the w5dpo i think)
Post by: Andy on October 11, 2008, 08:29:20 AM
Both Yoof and I found that running WR4DP0 plugs meant the cars started eating rotor arms (which also have a suppression resistor in them). We've both since switched to non-resistor plugs.
Post by: vwmk3jon on October 11, 2008, 11:38:40 AM
rotor arms aren't expensive though but cheers for the info. I'll get some W5's ordered in.
Post by: Andy on October 11, 2008, 04:36:25 PM
True, but it is annoying changing rotor arms at the side of the road if/when they properly go bang.
Post by: vwmk3jon on October 19, 2008, 10:39:25 PM
ah, didnt realise that they could go off like that! Don't really wanna find out either!
Post by: Yoof on October 23, 2008, 12:14:42 PM
NGK Plugs in my experience are far better...
I've got a few more sets to try then will be buying a batch and selling them- they're about half the price of Bosch too...
Post by: PeteG40 on October 23, 2008, 12:45:41 PM
ngk equiv of w5dp0 are bp7evx and are about £20 a set!
Post by: vwmk3jon on October 23, 2008, 01:49:06 PM
That sounds more reasonable imo. I'll probably buy a set of the W5's just to give the engine a spring clean for the eaton conversion and then try a set of those to see if theres any difference.
Post by: PeteG40 on October 23, 2008, 02:02:09 PM
some people in the past have had issues with ngks on relatively standard motors - i.ve used them and not had a problem personally.
Post by: G40DAS on October 23, 2008, 11:24:55 PM
I've been usig the NGK's too, didn't have a problem with them, but I do think they will need replacing more often than W5's. I'm back on Bosch currently.
