hi all im putting a g40 turbo into my mk1 golf i have the loom but i only have the sensors off of the gt all i need to no is which sensors i can used from the gt and which ones i need to buy.
cheers all
gaz
lambda probe
blue temp sensor
dizzy/hall sensor
oil pressure sensors
are all the same, that's all I can think of! Ones that are g40 only:
map sensor (inside the ECU though so I assume you already have that)
co pot/air temp sensor
+knocking sensor
yeah I knew I'd forget at least one, that's G40 only too.
thanks for that lads i no where the knock sensor goes
does the co pot/air sensor go on the boost pipe?
and is there only those that are different?
thanks again
gaz
yeah co pot/air temp sensor is the one clipped into the solid boost pipe.
