I am looking for some HT leads for the G, what does everyone else use?
There are some bosch ones on ebay but 2 different sets are listed for the G so a bit confused on which ones to get.
Are they the same as the GT ones?
all mk3 leads are the same. To be honest you can't go wrong with the german made ones from GSF. The make used to be Beru but more recently has been BBT. THey are about £30 a set and good quality.
cheers hayes!
which set though
92620H IGNITION LEAD SET-BQ PO 1.05 / 1.3 5/84>
92621C IGNITION LEAD SET PO 1.05 / 1.3 91>94
2nd set?
the BQ at the end means
Better Quality..
so im guessin the 1st set.. most likely the slightly dearer set
yup that's right./ They should be about 30 sheets.
