Technical => Chassis & Braking => Topic started by: ahmed bayjoo on April 07, 2009, 04:16:14 PM
Title: bleeding brakes
Post by: ahmed bayjoo on April 07, 2009, 04:16:14 PM
can anybody tell me the correct method to bleeding the brakes,
not sure how it is done if you dont have rear calipers.
thanks
Title: Re: bleeding brakes
Post by: PeteG40 on April 07, 2009, 04:38:40 PM
bleed the rear drums from the cylinder nipple at the back fo the drums - starting with furthest run from the master cylinder.
Post by: Dan on April 07, 2009, 06:15:55 PM
A tip is to hold open the rear pressure regulator so as to not restrict the fluid to the rear drums. A tiny cable on the pressure reg does the trick !
Post by: PeteG40 on April 07, 2009, 06:59:06 PM
true dan.. or i pull it open and lightly clamp it with mole grips
