Technical => Electrical => Topic started by: CSPgodzilla on September 17, 2023, 12:38:19 AM
Title: Dashboard Backlight off
Post by: CSPgodzilla on September 17, 2023, 12:38:19 AM
Hi,
All lights work, dimm works, clock light, cigarret lighter works, but dashboard light does not switch on, at night when I switch the healights.
Where could be the problem?
Title: Re: Dashboard Backlight off
Post by: PeteG40 on September 21, 2023, 12:36:00 PM
Likely the bulbs have gone!
Post by: CSPgodzilla on September 21, 2023, 09:32:01 PM
Thanks a lot
So, if a take it out (the DASH), I should find the lights that have gone off.
They are exchangable, right?
I could not find no information in the haynes manual.
Thanks a lot
Post by: CSPgodzilla on September 25, 2023, 10:15:15 PM
Quote from: PeteG40 on September 21, 2023, 12:36:00 PM
Can you give some guidance?
Post by: PeteG40 on September 26, 2023, 10:55:32 AM
you have to tilt forward the dash pod - (speedo/clock/rev counter)  and the two bulbs are on the top edge
Post by: CSPgodzilla on September 27, 2023, 12:14:00 AM
Can I make the wires to pull it out?
Post by: hayesey on September 27, 2023, 09:05:54 AM
the bulbs are like this:
https://www.heritagepartscentre.com/uk/431919040-dashboard-bulb-holder-with-black-base.html
they just twist and pull out from the back of the dash pod
