Hi Guys,
Im after the oil return port side casing as mine is cracked on the threaded section of the port and leaking oil.
Someone must have one tucked away somewhere as a spare or repair?
After one in good condition with no porting.
I've had a look.
Only got one that would get you out of a hole!!(its not great)
or one where the oil drain still needs repair (but not as mullered as yours)
Thanks for checking Pete.
Are they both standard with no porting?
Whats the issue with the one you've labelled "its not great"?
If only external cosmetic damage im not bothered.
Could you message me a pic?
Cheers.
i'll try to get pics tonight.
pete
Cheers Fella. 8)
