I need to make sure I have counted the correct number of coolant hoses that connect to the cylinder head. Can anyone confirm if this is correct:
-2 to the radiator
-2 to the heater system
-1 to the expansion tank
Is that right or have I missed any?
Thanks!
2 go to the expansion tank, small one for return and bigger one on the bottom.
Also there is one from the water pump pipe that "u" bends to the thermostat housing.
Perfect, thanks :)
Dan Hedges ?.... Are you speaking with SFS? The guy working there has just told me as it seems were doing the same thing.. pm me.
