Technical => Engine and Transmission => Topic started by: stuG40 on October 05, 2015, 01:33:18 PM
Title: NO SPARK, any ideas??
Post by: stuG40 on October 05, 2015, 01:33:18 PM
any ideas? My G40 has being running fine after a recent rebuild + K03 turbo conversion. A few days ago the car just died, turned out to be no spark. carried out all the usual new coil, rotor ,hall sensor ect
when I put a HT lead straight onto the coil pack and turn the ignition on I get a single spark, then when I crank no spark.
I'm thinking ECU or loom? also I checkED the alarm and disabled the immobiliser, any idea??
thanks in advance
Title: Re: NO SPARK, any ideas??
Post by: GR40 on October 05, 2015, 03:13:16 PM
Check fuses! What immobilizer?
Post by: stuG40 on October 05, 2015, 03:25:02 PM
I checked all the fuses and relays
Post by: kwijibo_coupe on October 05, 2015, 04:39:16 PM
I'd be checking wiring first. Did you have the loom out to check during the rebuild?
Also check the engine earths too.
Post by: ereeiz on October 06, 2015, 12:49:12 PM
Replace your earths if they're old. They cause 1001 issues. Even if it looks fine, for the sake or about £3 you may as well change them.
Post by: stuG40 on October 19, 2015, 01:24:02 PM
for the interest of the forum... turned out to be the blue coolant temp sensor, advancing the ignition to 127 degrees and reading -40. thanks :)
Post by: JoeH on October 19, 2015, 10:23:46 PM
blue temp sensors are a common fault - they all fail eventually - just search this forum, and imo are worth replacing from time to time for that reason
