Club Sponsors => Polo Performance Parts => Topic started by: Yoof on January 10, 2009, 10:34:29 AM
Title: New G40 Maps- In Stock!!
Post by: Yoof on January 10, 2009, 10:34:29 AM
(http://i167.photobucket.com/albums/u124/Polo-pp/Untitled-2.png)
Polo Performance Parts are pleased to announce a new range of chips aimed at modified Polo G40 owners wanting to maximise the potential of their modifications. Custom remaps are also available.
We have the following ECU Chips in stock - contact us with your specific requirements if what you need isn't listed:
Polo GT
·   Map #GT001 – chip suitable for standard cars or those with minor modifications, e.g. 4 Branch, Uprated Air Filter, Ported Throttle body. Raised rev limiter to make the most of a GT short ratio gearbox. £30
Polo G40
·   Map #G40001-1272cc 'Entry Level' chip- fuel map calibrated to accommodate extra boost from a 65mm pulley whilst retaining standard injectors & engine components. £30
·   Map # G40002-1272cc chip- an aggressive ignition map allows for an uprated camshaft to make the most from a ported supercharger and 65mm pulley, this chip requires accurate set-up of ignition timing. £50
·   Map #G40003-1272cc chip- for owners who are reaching the limits of standard injectors. This map allows larger 250cc/min units to be installed- as recommended for 165bhp+ Recommended modifications are; ported supercharger, 65mm Pulley, larger intercooler, colder spark plugs. £50
·    Map # G40004-1341cc chip- Designed as a 'safe' map with a conservative ignition map and generous fuel map it is perfect to run-in and set-up a freshly built 1341cc conversion. 250cc/min injectors need to be used with this chip. £50
·   Map #G40005-1341cc chip- A proven 170bhp+ has been achieved with this specific map. Calibrated to suit uprated 250cc/min injectors, 4-branch manifold, cylinder head modifications, aftermarket exhaust, large intercooler, aftermarket camshaft, 65mm pulley,  ported superchargers etc. £50
·   Map #G40006-1341cc chip- For the highest spec G40s out there. Proven at 185bhp+ for G40s with the above modifications with the additions of Aquamist & Big Valve Head- Aquamist is required due to aggressive ignition calibration. £50
Polo G40- Turbocharged
·   Map #G40007-1341cc chip- Enabling turbo owners to maximise the limits of the standard MAP sensor at 15psi. Should be used with 250cc/min injectors, turbo specific camshaft, uprated intercooler and manual boost controller. Proven at 165bhp+ £65
·   Map #G40008- 1341cc chip- As above with altered parameters to suit a 6psi boost switch replacing the standard G40 WOT switch, giving a smoother more progressive drive. £75
·   Map #G40009- 1341cc chip- For an uprated MAP sensor & Boost Switch, suitable for up to 22psi of boost from a K03. Turbo specific camshaft, uprated intercooler, Aquamist, 310cc/min injectors and a Forge Actuator are required. Proven at over 200bhp and 185lbft! £100
Uprated MAP sensors available on request. £35 each, or £100 fitted.
G40 and GT chips can be supplied with custom rev limits on request, at an additional cost of £5.
We can offer a full custom mapping service to suit your individual needs. contact us for details.
Title: Re: New G40 Maps- In Stock!!
Post by: poloeatonm45 on January 10, 2009, 10:46:14 AM
hi are you gonna be doing any chips to suit an eatoned g40?
steven
Post by: giorgio on January 10, 2009, 11:46:34 AM
Long term for me, but more beneficial to you in the short term; A chip for a 1.4 or even a 1.6 GT.
Post by: Yoof on January 10, 2009, 02:37:52 PM
Steven- In the future we will have the ability to custom map cars, so would be able to cater for eatoned cars too.
Post by: juan on January 13, 2009, 02:21:22 AM
What sort of price would i be looking at for a custom map/map fine tuning of my car once its up and running?
Juan
Post by: Yoof on January 13, 2009, 07:56:33 AM
Circa £250-£300. Can I just make clear that we will do this in our spare time, Andy is a Calibration Engineer for Ricardo so has the necessary credentials to map Polos  :)
The main issues with mapping arise when a project car comes to you with several niggling problems, all which may not be apparent to the owner. We'll also offer a G40 health check service sometime in the future, diagnosis of problems, fine tuning cam/ignition timing etc.
giorgio- 1.4 and 1.6 Digifant maps are on the cards, Andy's currently hacking the stock stuff to pieces so when know where each individual maps are  8)
Post by: vwmk3jon on January 13, 2009, 03:14:08 PM
uprated map sensors - like a G60item for example so i can run more boost with an eaton? I'd be interested if so.
Post by: Yoof on January 13, 2009, 04:03:37 PM
The very ones  ;)
Post by: breadman on January 13, 2009, 08:05:44 PM
Hi Pete,
How about you get a full list of all the parts you sell through your company?
I'm sure most are aware of your subframes etc, but it'd be good to have a full list of everything with current prices and availability.
I'll be interested in a Map#G40009 and an uprated map sensor in the future.
Post by: vwmk3jon on January 13, 2009, 10:26:57 PM
sweet. Whats the postage on these sensors and how hard are they to fit? I'll have to have a word with Phil ;-)
Post by: Yoof on January 14, 2009, 11:46:53 AM
Richard- We're currently having a big reshuffle, Andy now helps me with the business, we've also stopped selling any German made parts as they're currently too expensive. Once we've sorted things out properly I intend to have all that we sell in stock, even with our current limited product range that's a few grands worth, which we're a long way off!
Jon- Postage is £5, they're light but I'd rather send them insured  :) If you can solder then they're simple to fit, what do you need to speak to Phil about?
Post by: hayesey on January 14, 2009, 12:26:24 PM
the hardest part of fitting them is de-soldering the old sensor from the PCB.  If you've got a decent temp controlled soldering iron and a solder sucker then it's no problem really.  I imagine yoof will offer a fitting service where you send him your ECU and he'll get the sensor fitted for you.
Post by: vwmk3jon on January 16, 2009, 09:04:33 PM
Phils fitting my eaton kit & 1341 for me, plus some other bits and bobs. I'd do it but i wouldnt give it 5mins before it explodes! Why you ask?
Post by: hayesey on January 16, 2009, 10:36:40 PM
phil who?  ???
Post by: Yoof on January 16, 2009, 11:11:23 PM
Phil J ???  ???
Post by: vwmk3jon on January 17, 2009, 06:59:14 PM
 :D
Post by: Phil on January 18, 2009, 01:13:13 PM
Whoooooooooo-oooooooooooooo are you, who who, who who.....
Post by: itsadubthing on January 18, 2009, 04:35:47 PM
tried to private mail you but no luck lol
hi mate, do you have one of the above in stock.  and does this best suit my car (well as far as an off the shelf mod goes) heres what i have
stage 4 charger
k and n filter
piper cam
de-wedged throttle body
65mm pulley( well when i get the chip that is)
full throught stainless exhaust
many thanks for you help
Craig
Post by: Nick_S on January 18, 2009, 05:28:39 PM
Might be interested in one of these. The base map on my current one for 300cc reds is very erratic at low throttle, once the micro switch is engaged for a short period.
Post by: muir26 on January 18, 2009, 07:03:27 PM
Hi I have just rebuilt my 1341 with a
big valved head and newman cam
310cc red top injectors ( I still have the green top 250cc I think if that would suit your map better )
stg 4 Jabba charger with toothed belts
it still has the standerd exhaust manifold but with a custom downpipe and exhaust
GT inlet with de-wedged TB
and a bigger front mount intercooler
I'm looking for a chip to run this engine in could you tell me what chip would be best suited?
Cheers Dave
Post by: Andy on January 19, 2009, 05:59:33 PM
Quote from: muir26 on January 18, 2009, 07:03:27 PM
Cheers Dave
Hi Dave - just in case you don't see my reply on Club Polo:
I'd recommend Map #G40005 for that spec, but you'd have to use your 250cc/min injectors.
You won't need the 310cc/min units until you're pushing 200bhp - and you'll need to run smaller than a 65mm pulley on the G40-lader or ditch it for something else to achieve that with 1341cc.
Cheers,
Andy
Post by: Andy on January 19, 2009, 06:02:53 PM
Quote from: itsadubthing on January 18, 2009, 04:35:47 PM
stage 4 charger
k and n filter
piper cam
Craig
Hi Craig,
Assuming you're 1272cc and running standard injectors then I'd recommend either Map G40002 or Map G40001.
Andy
Post by: Robin on January 23, 2009, 10:28:33 PM
Gotta just add that Yoof and Andy are very clued up about these maps which they are selling, i have been a map mule for most of the G lader maps and Andy is always ensuring that each map is correct for the spec.
All the G lader maps are tested and proven so if anyone is worried out the quality of the maps then don't be.
Extremely happy with the level of knowledge with both guys!
Post by: domisgar on February 01, 2009, 06:18:48 PM
Hay
Im in the market for a new new chip and been recomended by many to speek to you!
my spec at the mo is
PDS 65mm toothed pully
full blend +
fmic
brm
stand alone oil supply
13row oil cooler
4-2-1 de-cat exhaust
sebring 63mm straight tho exhaust
ive got a gt manifold but not fitted and was thinking i might need 250cc incectors?
which chip do you suggest?
Dom
Post by: Yoof on February 02, 2009, 06:22:50 PM
Hi Dom,
Thanks for the PM, what's 'BRM' Boost Return Mod?
Depending on your future plans- if you're aiming for more power it may be advantegeous to fit the 250cc injectors and gt inlet at the same time.
We can do maps to suit your stock injectors or 250cc/min ones.
Peter
Post by: Robga on April 14, 2009, 09:08:06 PM
Hi
Ive sent a couple of PM's to yoof but had no reply back so im not sure if they are being recieved.
I would like to purchase a G40 chip - map G40005.
Could I have payment details to transfer the money.
Rob
Post by: Andy on April 15, 2009, 07:29:06 PM
Rob & Dom - you should both have PMs back from me. :)
Post by: g40chris on May 10, 2009, 07:11:14 PM
can i use the Map #G40005 on a 1308cc engine, everything else on the list i have
Post by: Andy on May 10, 2009, 07:19:04 PM
If you're 8:1 CR rather than the 9:1 of the Accralite pistons you may benefit from a little more ignition advance than the chip offers, but for a generic chip to get you up and running it should work well.
Post by: g40chris on May 10, 2009, 08:25:29 PM
im not sure about the CR to be honest
they are carl schmit 1308cc pistons and im using the metal head gasket
its running at the moment with the custom map it had from pitstop a few years ago, but that was set up for the eaton and smaller pulley, now i have the glader with 65mm pulley so im sure air/fuel will be way off. runs ok but sounds a little rough so i would rather something more suitable
Post by: g40chris on May 11, 2009, 06:48:17 AM
any idea what CR the pistons would give me
Post by: dazzle53 on June 18, 2009, 06:22:08 PM
hi how do i go about ordering a Map #G40003 chip?
this is all new to me...
Post by: throbtherob on July 07, 2009, 03:28:01 PM
Hi
I would like to puschase a G40003 chip,can you PM me some payment details,also does your chip replace the removable one under the metal shield in the ecu?
Regards Rob
Post by: Andy on July 09, 2009, 02:18:49 PM
Yes, the chip replaces the one under the metal EMC shield.
If you're interested in a chip, please send me a PM with your engine specification and I will advise as to the most appropriate item (we have a few 'flavours' of the chips advertised for slightly different specs) and send payment details by return.
Post by: markh450 on July 27, 2009, 01:51:20 PM
Hi
I have a G40 which is basically standard apart from the following:
4 branch manifold and stainless system
drilled airbox
I want to go for a 69mm pulley and a chip to suit (I thought I'd go for a 69mm (ish) rather than 65mm to save wear on the charger, if this makes sense??)
can you supplly the chip and pulley?
Mark
Post by: markh450 on July 29, 2009, 09:46:34 AM
Hello
I have now managed to get a pulley from Jabba sport (65mm) and need a chip. my spec is in the post above, I'm assuming i will need Map #G40001 ?
I could do with it fairly quickly as I am putting the pulley on on Friday and don't really wnat to run the car too long with the pulley and no chip.
can you let me know payment details, I can wire across or use the missus' paypal account.
Mark
Post by: dazzle53 on August 28, 2009, 01:39:26 PM
hi i'd like to order the Map #G40003 for my g40. how do i go about this??
Post by: Andy on August 30, 2009, 09:55:29 AM
Hi there,
Send me a PM with your car's specification and your address. I'll send you payment details by return, and get a chip out to you once you've paid.
Cheers,
Andy
Post by: dazzle53 on August 30, 2009, 12:03:12 PM
will do mate, just need to find what cam im guna run
thanks
darren
Post by: nikky on September 23, 2009, 11:32:49 PM
pm'd :)
Post by: LeonL on September 23, 2009, 11:39:02 PM
PMed also <3
Post by: Andy on September 24, 2009, 10:09:09 AM
PMs replied to.
If it's chip stuff then it's best to PM me rather than Yoof. ;)
Post by: VW_rae on October 16, 2009, 12:43:30 PM
in need of a map sensor can you pm details please
Post by: Andy on October 16, 2009, 06:46:08 PM
PM'd you back on Club Polo Rae.  ;)
Post by: giorgio on December 02, 2009, 10:33:15 AM
Yoof did you ever get round to looking at a 1.6 GT map? My engine is getting tweaked over christmas and I dont want to sacrifice my stand-alone for a GT.
Post by: Yoof on December 02, 2009, 02:58:53 PM
Would need to be a custom map- but we can do it  :)
Post by: ek4_t on March 05, 2010, 11:41:18 AM
hi yoof
wanted to know some things about a chip and a sensor 250
pm sent
Post by: ek4_t on March 08, 2010, 08:57:30 PM
hi Yoof
I am waiting for answer to a pm I sent you
wanted to order the sensor chip and the car is ready so the left and the sensor chip to run
how do I pay
Post by: g40_ER on March 11, 2010, 12:27:14 PM
I'm new here in the forum, but I saw that you sell chips, and members are very happy with the chips
I would like to know how to buy a chip for my g40 turbo
hug
Post by: poloeatonm45 on March 22, 2010, 05:08:59 PM
do you offer a fitting service for the 250 map sensor? i.e i send you my ecu and map sensor and you fit the new one for me ? let me know
steven
Post by: Andy on March 22, 2010, 06:02:19 PM
Yes we do. This is £100 + P&P if you want this service - alternatively we can supply a MAP sensor with fitting instructions for £40 + P&P.
Please note that as I modify the ECUs in my spare time the turnaround will be approx 4 weeks, as my day job and DIY are keeping me bloody busy! If you need one in a rush let us know before ordering and we'll advise what we can do.
Andy
Post by: Richg40 on May 13, 2010, 12:45:49 PM
Are you able to knock up a safe map for a 1w set up?
Post by: Andy on May 24, 2010, 08:58:09 PM
Hi Rich,
If you send me a PM with your spec I'll let you know what your options are.
Andy
Post by: sinister polo on June 28, 2010, 09:56:45 PM
hi andy would you be able to do me a Map #G40007 chip but for 1272cc instead?
Post by: Andy on June 29, 2010, 07:31:45 AM
PM me your spec and I'll let you know what we can do.
Post by: matthg40 on October 31, 2010, 08:33:10 PM
hello mate just wondered which would suit my polo best
modificaitons as follows
jabbasport r5 supercharger
g60 injectors
ported and de-wedged throttle body
toothed belts and pullies
powerflow stainless backbox and stainless steel pipe from cat back
but cat has been removed
hope that helps with which one would suit my car best
many thanks matt
Post by: Yoof on October 31, 2010, 08:48:07 PM
Hi Matt,
What's the R5 Jabba charger? Also are the pullies 65mm?
Post by: matthg40 on October 31, 2010, 11:17:46 PM
hello pete will give you an answer of size of my pullys tomorrow
Post by: matthg40 on November 01, 2010, 06:32:06 PM
hello pete
the r5 supercharger is just a stage 5 supercharger basically
and i am also using a 60mm pulley believe it or not
hope this helps with answering my question of which remap i would need look forward to hearing from you with an answer
many thanks matt
Post by: matthg40 on November 01, 2010, 06:34:09 PM
oh i forgot to ask how would an uprated map sensor help my g40 my polo boots just over a bar of boost if you need to know that
Post by: hayesey on November 01, 2010, 08:08:29 PM
Don't jabbasport normally call that an R1?
Post by: matthg40 on November 01, 2010, 08:41:57 PM
yes mate i put that on  my original post pete asked what the r1 meant  ;D
Post by: hayesey on November 01, 2010, 09:08:07 PM
You said R5 :)
Post by: matthg40 on November 01, 2010, 09:25:30 PM
oh yes so i did my bad must have had a blonde moment apolagies for that matey ;D ;D
Post by: Andy on November 06, 2010, 11:03:24 PM
Quote from: matthg40 on November 01, 2010, 06:34:09 PM
If it's only just over a bar I'd stick with the stock MAP sensor.
You using standard head, cam, bottom end and intercooler?
Post by: matthg40 on November 07, 2010, 09:49:21 PM
im using my standard head and cam i only gained the extra boost due to my toothed belt and pulleys ill stick with the standard map sensor im just rather keen to remap my polo so if someone can get back to me with an answer that would be awsome thanks
Post by: langersG40 on November 14, 2010, 08:59:36 PM
Hi im interested in one of your chips stage 1 what some of gains HP and Torque wise would i get from it??
many thanks
chris
Post by: Andy on November 15, 2010, 07:08:48 PM
Quote from: matthg40 on November 07, 2010, 09:49:21 PM
We charge £300 for a G40 remap which takes a day with you driving and me mapping. Email enquiries@PoloPerformanceParts.co.uk if you're interested.
Quote from: langersG40 on November 14, 2010, 08:59:36 PM
many thanks
chris
What's your current spec? We do chips to give safe fuelling and ignition timing for a certain spec - or full remaps to wring every last bit of power from your engine. Power gains will vary depending on your specification and what chip you're currently running.
Post by: langersG40 on November 15, 2010, 09:22:59 PM
at the moment its got the standard chip, and pulley, want to put 65mm pulley on with your chip and get my injectors cleaned by you to, just wanted to gain a bit more power than standard, what do you think i would get from the above too? ball park wise? sorry for this question new to G40 ownership byw :D
thanks in advance
chris
Post by: matthg40 on November 16, 2010, 06:24:16 PM
my spec on my polo is as follows
jabba sport r1 supercharger
g60 injectors
bored out ported and polished de-wedged throttle body
toothed belts and pullys running a 60mm pully
powerflow stainless exaust system from cat back with cat removed
so i would like to know which ecu chip would be best suited to my car many thanks matt
Post by: xandyx on March 16, 2011, 01:13:11 AM
can you please tell me whats the rev limit of #G40001?
i want to go from totally stock to a 65mm pulley and i'd like a chip to match! i have in the shelf a sns nolag but i think it's too agressive for such mod.
greetings
André
Post by: Andy on March 25, 2011, 06:42:20 PM
xandyx - Rev limit is 6600rpm, but can be changed to whatever you like.
matthg40 - G40003 is best for your spec. Do you really have a 60mm pulley? 65mm is normally the smallest size used.
Post by: Andy on March 25, 2011, 06:43:24 PM
Any new enquiries, please email our chips address:
chips@poloperformanceparts.co.uk
Post by: vwmk3jon on April 01, 2011, 01:04:51 PM
Can i order a chip please? (G400009)
Post by: Andy on April 03, 2011, 07:09:50 PM
Email the above address and we'll sort it. A full engine spec list is also helpful in your email, we have several 'flavours' of each chip so try to give you the most appropriate setup for your mods.
Post by: vwmk3jon on April 03, 2011, 08:06:21 PM
Done ;)
Post by: youngprodigys on August 30, 2011, 07:29:55 AM
all the turbo maps are for 1341, do you have 1272 maps?
Post by: josé on September 16, 2011, 01:45:27 PM
can i have payment details for a base map for my g40 turbo conversion please??
i have pm'd you both regarding this
thanks josh
Post by: Yoof on September 16, 2011, 04:14:10 PM
Yo Josh- email was with you alst week about it dude, payapl: enquiries@poloperformanceparts.co.uk
Post by: josé on September 16, 2011, 06:04:00 PM
i never received an e-mail from you for some reason,
i've just paid for the base map  :)
i'll pm you my address to send it to.
thanks josh
Post by: dub-disaster on September 16, 2011, 07:33:36 PM
im after a custom map at the next availible free date please
Post by: Andy on September 16, 2011, 08:01:29 PM
Quote from: youngprodigys on August 30, 2011, 07:29:55 AM
Yep, there are several 'flavours' of most of our advertised maps.  ;)
Post by: josé on October 01, 2011, 01:55:49 PM
hi guys,
Any ideas when i'll get the base map for my car? because i want to get it running.
thanks josh
Post by: Andy on October 01, 2011, 04:58:12 PM
Should be with you by Monday Josh.  :)
Post by: josé on October 01, 2011, 06:34:41 PM
thats brilliant, hopefully i can get it running etc, then arrange a date for mapping.
thanks josh
Post by: grungeisdead on November 30, 2011, 04:23:30 PM
Have you got a map suitable for the following
T25 Turbo
G60 Green Injectors
250kpa MAP Sensor
GT Camshaft
GT Inlet
Dewedged TB
Jabba Induction Kit
6psi boost switch
Basically I have an unknown turbo map, unsure if it can be unpicked to find out what spec its for, but I do want to upgrade to a 250kpa map sensor and G60 greens (currently running std MAP and G40 injectors)
ta
Post by: Andy on November 30, 2011, 05:25:37 PM
Not got owt like that off the shelf Saf, would have to be a custom map. I've yet to see a car that has a true 'T25' map - all I've seen so far have been copies of Marshall's old chip, which was a G40 greens map with shitloads of fuel thrown in above 4000rpm.
Greens will be pretty much on their limit at 200bhp on a G40, so depending on what boost levels you're thinking of running, you may want to get larger injectors.
Post by: poloandyb on November 30, 2011, 09:42:26 PM
hi im after a chip please for a g40 engine with gt manifold,r1 charger,intercooler,65mm pulley,slightly ported head and manifold,exhaust.
future plans are g60 injectors,4 branch,51mm throttle body
could you please tell me what might be the best chip for the job thanks
Post by: grungeisdead on November 30, 2011, 10:39:05 PM
No worries fella, idles well and drives reasonably well, but I've always known it'll need a decent map for longevity and just to drive as well as it possibly can.
I'm not wanting to push massive power, the 170bhp that the g-ladered lump was more than plenty, and probably what I want to run with this, means it should be quick and reasonably reliable.
Whats your available like over Dec/Jan for mapping? and what sorta price we looking at? Is it done by the hour, or X amount for a mapping session and Y for tweaking later?
It is worthwhile getting larger injectors now, and getting the map done to suit, or just sticking with the greens if im happy around 170-180?
Post by: Andy on December 01, 2011, 08:46:23 AM
Quote from: poloandyb on November 30, 2011, 09:42:26 PM
G40003 would suit your spec. Priced at £50 plus £5 P&P. Email: chips@poloperformanceparts.co.uk to order.
Please note I'm currently away with work, so it might take 10-14 days before I post your chip.
Post by: Andy on December 01, 2011, 08:52:59 AM
Quote from: grungeisdead on November 30, 2011, 10:39:05 PMWhats your available like over Dec/Jan for mapping? and what sorta price we looking at? Is it done by the hour, or X amount for a mapping session and Y for tweaking later?
I'd stick with the greens if you're aiming for 170-180bhp, and I think you'll also be able to stick with the stock MAP sensor at that power too. A K03 and turbo cam at 15psi is good for 170-175bhp, so a T25 with GT cam is likely to be in a similar ball park.
We charge £300/day for mapping, and that's plenty of time to get a map done as long as there are no mechnical failures and we start mapping in the morning. I've got no availability during December (I'm away with work at the mo), there might be 1 slot at the end of Jan - but it can be very weather dependant at that time of year!
Best to email our chips address (chips@poloperformanceparts.co.uk) to arrange getting booked in - I've got a few people on a waiting list already for the New Year.
Post by: gaz g40 on December 04, 2011, 10:20:54 PM
you guys have an email for the g40003 chip thanks
Post by: N1CKY on December 04, 2011, 11:12:47 PM
Looking to get a chip from yous very soon, Within the next few weeks hopefully. As i emailed S-tech and they said my current chip is only setup for 1 bar of boost? So does that mean it would of been running lean above 14psi ? Anyway more to the point. What would be the best chip to use.
Current turbo setup:
Volvo T5 turbo on a tubular manifold.
250cc injectors
Turbo cam ? Im not sure what make it is, Its only got 3 numbers on :S but the lobes are pretty big and it looks like its got marks where its been profiled.
GT inlet with Dewedged TB.
unsure about the map sensor ? Will be buying one from you most likely.
Ported and polished head
Front Mounted IC
Thanks,
Nicky.
Post by: timmitime on December 13, 2011, 08:33:06 PM
Hi my car is now running and driving so will be ready for mapping as soon as you have a spot free I have emailed you a few times on your other email address could you please let me know when you have a spot free ?
Post by: Andy on December 13, 2011, 09:05:52 PM
Nicky - PM'd you back again.
timmitime - will ping you a reply via email. I'll start doing mapping again end of Jan 2012, at the moment the weather's too bad to do any on-road mapping.
Post by: Oli b on January 05, 2012, 08:54:50 PM
hi just wandering what chip to have my engine spec is
standard 1272 g40 head and block
jabba stage 4 charger
65mm pulley on twin v belts
dewedged tb
gt inlet
cat back stainless exhaust system
no cat
bigish intercooler (bout 3times the size of a standard g40 intercooler)
has a jabba chip in atm that was suplied when the charger was stage4,d along with a 65mm pully
should i stick with this chip or is this at its limit?
cheers guys
Post by: langersG40 on January 12, 2012, 08:47:52 PM
hi just wandering what chip to have map 001 or 002 my engine spec is
PSD Full blend charger
was also interested in getting the injectors cleaned too, i did email about this but never got a reply??
many thanks
chris
Post by: brownysblower on February 01, 2012, 03:45:28 PM
Hi
has my chip been dispatched yet
many thanks
Post by: poloandyb on February 01, 2012, 03:54:31 PM
if i put my order in tonight for the g40003 chip,how long should it take to arrive.just trying to work my time line out for puttin my r1 charger on
cheers andy
Post by: Andy on February 01, 2012, 05:27:28 PM
Quote from: brownysblower on February 01, 2012, 03:45:28 PM
Hi
many thanks
Will be with you on Saturday.
Post by: Andy on February 01, 2012, 05:28:16 PM
Quote from: poloandyb on February 01, 2012, 03:54:31 PM
cheers andy
I'm doing a batch on Friday, so if your payment has cleared by then it'd be with you on Saturday.
Post by: poloandyb on February 01, 2012, 06:18:00 PM
sent you guys a email for the chip
Post by: N1CKY on March 19, 2012, 12:49:12 PM
Any news on my chip lads ? Need it ASAP, Its booked in for the rollers on Saturday.
Cheers.
Post by: g40fox on July 11, 2012, 10:19:29 PM
hi can you supply me with a chip cars not runnning rite think this could be the cause if so how can i get in contact
Post by: Andy on July 12, 2012, 03:18:10 AM
Email your full engine specification to: chips@poloperformanceparts.co.uk and I'll get back to you.
It's always worth checking the engine diagnostic guide on here to verify all sensors are working properly and ensuring your ignition and cam timing are set correctly before relying on a chip swap to address running issues.
Post by: RyanC on May 23, 2013, 11:24:30 PM
Still do these?
Post by: Andy on May 24, 2013, 07:48:57 AM
Yes.
Email: chips@poloperformanceparts.co.uk with your engine spec and requirements.
Post by: Etches on May 24, 2013, 05:36:29 PM
Cool Didn't realise your on this again, congrats on the little un Andy
Post by: Andy on May 24, 2013, 05:52:09 PM
Still doing chips, but it'll be a few weeks at least before I book any custom remaps in.
Post by: RyanC on May 24, 2013, 08:06:56 PM
I've sent a message about 3 weeks ago but ill send it again :)
Post by: physicsfool on July 16, 2013, 01:31:46 PM
I dropped you guys a chip related PM
Post by: physicsfool on July 28, 2013, 12:13:47 PM
Quote from: physicsfool on July 16, 2013, 01:31:46 PM
Any news? Cheers
Post by: gaz g40 on November 15, 2013, 06:47:05 PM
Hey guys after a chip to run in my 1341 supercharged engine with 250cc injectors thanks guys
Post by: physicsfool on January 08, 2014, 10:34:57 AM
Hi Chaps, is custom remapping a possibility later this year (spring/summer)? Cheers
Post by: Etches on January 08, 2014, 02:54:32 PM
I'm with Martin on this, need it doing when I jump up to 1.5 bar
Post by: Yoof on January 08, 2014, 05:09:16 PM
Once the weather is a little better then yup!
Post by: Etches on August 06, 2014, 06:49:06 PM
Andy I'll send you an email aswell, looking for a bigger map sensor and 22psi turbo map. I'll obviously have to send you my spare ecu. You can either pm me or reply to my email.
Tom
Post by: joseleeds on October 03, 2014, 04:00:47 PM
I dropped an email to 'chips@' a while ago. Just wondering if it's better to get in touch on here?
Joe
Post by: doddy1988 on January 17, 2015, 11:15:28 AM
I'm after a g40005 chip please
Post by: Bushpig on January 28, 2015, 06:26:31 PM
Hey ,
I purchased a g40 chip 0002 of a member of here , now the car eventually will have stage 4 charger , piper cam , 65 mm pulley shortened belts , k&n panel , port n flowed , colder plugs , now is this too much for chip or bang on?
Would a generic map be safe enough or a live chip be better ?
Plus it says engine timing needs to be cock on ? By timing light? Dizzy cap?
Cheers Danny.
Post by: Andy on January 28, 2015, 07:36:18 PM
There are several 'flavours' of each of our chips, so I try to match it to the original purchaser's spec. If you can let me know the serial number of the chip I can give you an idea of what mods it was done for.
Post by: Bushpig on January 28, 2015, 08:58:26 PM
Cracking job have to find it ha.
Cheers.
Post by: Bushpig on January 28, 2015, 09:46:22 PM
In fact if you have a members list or sold to list
Was martins (physicsfool) from Malton
found chip ser: 00000113a
Cheers Danny
Post by: Andy on February 06, 2015, 07:39:45 PM
Quote from: Bushpig on January 28, 2015, 09:46:22 PM
Cheers Danny
Looked it up now you've added the serial number... It's just a straight G40002 map, so for stock injectors; chip and pulley and aftermarket camshaft.
If you've had the head ported then the chip should be okay with mild porting, but head mods can be a lottery with some being wildly different to others - so a custom map can be beneficial.
Post by: Bushpig on February 06, 2015, 08:09:29 PM
What is pricing and arrangements for one of those ?
I would prefer a custom job for peace mind.
Cheers Danny.
Post by: G40shawn on February 10, 2015, 08:28:57 PM
I'm after a g40002 if possible?
Post by: Andy on February 10, 2015, 09:43:23 PM
Lads, if you can email: chips@poloperformanceparts.co.uk with chip requests please. If you stick your full engine spec in the email we can advise on what we have to suit best.
Andy
Post by: Bushpig on February 24, 2015, 01:04:53 PM
Sent a email of my specs not received anything back as of yet , but I did hear you guys run this in spare time.
Just checking that email got to you.
Cheers Danny.
Post by: Tonyxxx86c on May 22, 2015, 08:28:23 PM
i have sent an email
Post by: Tonyxxx86c on June 29, 2015, 09:56:22 AM
why don't answer at my email,  post or mp?
Post by: Duque on October 01, 2017, 12:58:00 AM
Hello PPP,
  Still do these..?
Post by: dazzle53 on September 02, 2018, 01:42:32 PM
Chips still available?
Post by: Yoof on September 07, 2018, 09:29:24 PM
Yup yup  :)
