Hi there,
I have a turbo conversion for sale that comprises of the following.
Genuine KKK K03 turbo with forge actuator
Rothe manifold
Downpipe with heat wrap
Forge dump valve
ECU with PPP turbo chip and 250kpa map sensor
315cc injectors
Front mount intercooler and suitable silicone hose. As you can see from the pictures below the intercooler is a great fit at the front of a mk3 polo. Silicone hose included was over £100 alone.
Newman PSD turbo cam
Nearly new set of tappets for the cam
Throttle body with boost switch installed and welded up elbow.
Tapped sump for the oil drain
Oil and coolant lines
Air filter
Alternator
Engine mounts
Pulleys
Suitable spark plugs
Bumper bar with hole cut in to allow cooling for the intercooler.
Front bumper with holes cut in to allow cooling for the above bumper bar.
Basically everything needed to convert straight to turbo. I have run this setup for a while and it has made good power and made for a quick car. This setup is located in Sheffield. £950.
(http://i6.photobucket.com/albums/y238/baldwins/9557fe6cb15a7e1c5496193ba11a0901_zpsf8964d49.jpg?1433612459550&1433612476088&1433612490682)
(http://i6.photobucket.com/albums/y238/baldwins/5e39fef95dc7fad9c5ca4ae7613d8420_zpsba1a9815.jpg?1433612459550&1433612476088&1433612490682)
(http://i6.photobucket.com/albums/y238/baldwins/18a1772ee496a1e08f11fd7f38e675f3_zps6beaf431.jpg?1433612459550&1433612476088&1433612490682)
(http://i6.photobucket.com/albums/y238/baldwins/d7cffa4801ddf8e1d62d25808989e6c1_zpsd5816355.jpg?1433612459550&1433612476088&1433612490682)
(http://i6.photobucket.com/albums/y238/baldwins/7966928158e374391c37dc2d1779796a_zps1467e2d9.jpg?1433612459550&1433612476088&1433612490682)
(http://i6.photobucket.com/albums/y238/baldwins/A96EC6B9-2B5A-40F1-A7E1-098AE7520E7B_zpstwnjnujv.jpg)
(http://i6.photobucket.com/albums/y238/baldwins/7A5B8C50-AC9E-4783-9E43-9F21B6E72F67_zpspw3v1kff.jpg)
(http://i6.photobucket.com/albums/y238/baldwins/E01F89A6-5B62-4865-92DB-F819AAC7C2C7_zpsog2plioq.jpg)
Up.
i think i know the answer to this one but out of curiosity were you running a bored out forged/accrilite bottom end with this set up ? :)
Quote from: mk3amorpha on July 27, 2015, 03:50:59 PM
Nope he was running a 1272 bottom end
ooh cheers for the answer! sam if its still for sale id be interested in it :)
This still for sale?
