Technical => Engine and Transmission => Topic started by: krazy*k on May 13, 2015, 11:36:28 AM
Title: Engine feeling bogged / hesitation
Post by: krazy*k on May 13, 2015, 11:36:28 AM
Well i haven't been on here for a while ahah, but once again but with a problem.
The G was starting to play up and was well overdue some new parts so i have replaced plugs leads, dizzy cap and rotor arm.
She has run sweet for a few weeks and now the she back to feel bogged down and hesitating like a bitch you can push her through but even in low gears its a killer.
The plugs are NGK and i have OE leads, the dizzy cap and rotor arm were from Vindis and cost a packet.
What else can i try as she is now undriveable.
Title: Re: Engine feeling bogged / hesitation
Post by: physicsfool on May 13, 2015, 11:44:20 AM
Is fuel flowing fine? otherwise just coil pack and hall sender as well as making sure all the earths are clean and well attached
Post by: krazy*k on May 13, 2015, 11:53:27 AM
Perfect i shall give those a go :D
Post by: GR40 on May 13, 2015, 01:27:21 PM
Check the outside pump contacts as well, I had a similar problem like that some years ago and it was water getting in the contacts.
